Results 911 to 920 of 5002
February 16th, 2011 06:23 PM #911
To all Strada Fanatics,
I am calling all who bought a 2010 Strada GLS. Is your unit equipped with the 12V Auxiliary socket? I just got my strada gls this week and it is not present. I check the brochure and it was not a dealers option. I assume it is standard to the model.
- Mar 2009
- 154
February 16th, 2011 08:15 PM #912mga sir, ok lang ba gumamit ng top one synthetic oil, 15w-40 sa 3.2 strada.
pwede rin iba ipa align ang strda natin sa aside from casa? parang may nabasa ako na magkakapublema sa airbag?
thanks sa mga infos
- Mar 2009
- 154
February 16th, 2011 08:41 PM #913
February 16th, 2011 09:31 PM #914
- Feb 2008
- 162
February 17th, 2011 03:54 AM #915Hello Sir, from what I have read in the past posts, kung 15w 40 royal purple and pag 5w 40 motul. Other members have also used mobil. These three brands ok ang feedback from the members.
Personally I've only tried motul fully synthetic for crdi engines, Ok naman. There's a dealer of motul along EDSA and pag member ka pa ng Strada Club you get additional discounts.
February 17th, 2011 05:54 AM #916
motul crd sa autoplus. ok din idemitsu 5-40 extreme touring fully synthetic 400 pesos/L(for diesel and gas application nakalagay sa bote) and may 15-40 idemitsu for diesel engines 400/L
February 17th, 2011 07:19 AM #917
Sir Nismo and Sir Walter,
I'm planning to do this sometime soon...pero up to CDO lang...na cancel kasi last year due to short vacation leave.
Gusto ko sana alamin ang timing at deskarter sa ferry sa matnog at liloan...at ilang oras at ilang km ang layo bawat ferry?
Places to avoid etc...
Thanks in advance.
February 17th, 2011 09:29 AM #918
On vacation mode, you can leave early morning Manila up to Naga then from Naga to Catbalogan or Tacloban then Tacloban to Cagayan de Oro.
If you want to get to CDO fast, leave Manila 4:30 a.m. and overnight at Samar then to Liloan on the 2nd day and you'll be at CDO on 3rd day.
February 17th, 2011 10:09 AM #919
from matnog to allen, 4 hours interval ng barge... 4pm-8pm-2mn-4am- 8am-12nn
1 1/2 barge travel..
from liloan to surigao, 3 hours interval ng barge (not sure) .. 3am-6am-9am ...., 3 hours travel ng barge
from surigao to cdo, 5 hours siguro..
kung walang tulugan sir, kakayanin mo yan ng 36hours travel... HTH
February 17th, 2011 10:17 AM #920
partner, please take note of the following..... also to the other readers please remember this...
[SIZE="6"]as per regulations of the API, if your engine oil has a rating of 0, 5, 10 it is considered as a fully synthetic oil, 10, 15, 20 it is semi.. no other abbreviation it is straight mineral.
points for clarification: all oils are actually using mineral oil as base stocks, the only difference is the additives that they put to the oil to change it's lubricity, flash point, boil point, detergency, etc...
so if your oil says 5w-??? it is considered as synthetic by the API, and the same follows for all the other numbers. issues come out with the 10 rating, when it comes to the 10 rating it is considered safe to assume that the oil is only rated as being semi.[/SIZE]
high idle RPM at engine start
