Results 2,451 to 2,460 of 3019
- Dec 2011
- 34
November 25th, 2012 02:35 PM #2451
- Dec 2011
- 34
November 25th, 2012 02:41 PM #2452Thanks sa advise bro. Hindi naman. Hindi ko na naasikaso after nung unang palit ehh. Hindi nalang akk nag reremote. Saklap. Pero ayun nga your point makes sense. Halos 1s a week ko nalang yun nagagamit eh nagka ganun. Nung pinalitan naman nila yung battery. Gumana agad. I doubt kasi na sasabihin nila na may problem sa unit kapag gumagana na kapag pinalitan battery =.= or would you suggest a good casa? Walang kwenta kasi sa carworld marilao eh.under warranty pa naman asx ko till next month.
November 25th, 2012 03:23 PM #2453
Koya, I have no idea how they set it up. Basta may narinig akong matagal na grinding, pukpok, etc. sa loob ng room. Hehe. They gave me back my halogen projectors.
This is a Stage 3 bi-xenon, which uses a solenoid for the high beam. It has Philips Germany 85122+ D2S bulbs, plus free amber LED park light. They also retained my original high-beam bulb in the reflector. OA na ang quad. At namumulubi na 'ko.
Gary calls it "Stage 3 OEM HID Projector Retrofit" and says it's not a "boxed kit." He also says "only the best parts are used" and claims it will match or surpass the setup on the SE.
P.S. All the photos are low-beam lighting, no fog lights.
Sent from my GT-N7000 using Tapatalk 2
Tsikot Member Rank 1
- Jul 2009
- 4,090
November 25th, 2012 05:14 PM #2454sir check mo muna yung battery itself, kung may tester ka, yan kasi ang problem ng frequency based audio remote, kung yung usual na route/area mo eh nakakaapekto sa frequency nung audio remote mo, you need to reset it once in a while. sakin kasi tested ko may isang location na every time na nandun ako, ayaw talaga gumana yung audio remote. kung may cruise control yung unit mo sir pwede lagyan ng connection yan, but if wala, negative. but kahit connected na directly to battery, if the frequency interference, hindi rin gagana yan
- Sep 2012
- 11
November 25th, 2012 09:13 PM #2455
Yes sir sa loob po yun installation na ginawa. mga 3 hours ginawa, dun natagalan sa opening ng headlights ginamitan nila ng blower para lumambot at maghiwalay then madali na paglagay nun Led strip. 2300 lahat gastos me charge yun pagopen ng headlights pero yun LED strips mura lang naman
Here's some pictures kapag madilim na:
lights 019 by bonclem, on Flickr
lights 020 by bonclem, on Flickr
lights 021 by bonclem, on Flickr
November 25th, 2012 09:30 PM #2456
Thanks. I have complete tools naman and used to open plastic hls. Either tinatamad or ayaw ko pa paglaruan headlights ko. Hehe
- Dec 2002
- 2,335
November 25th, 2012 11:16 PM #2457the stock halogen projectors are with pipefish. yes it was replaced with a bixenon HID projector. the ballasts were attached oem style, i.e rigidly mounted under the headlights. yes LO and HI or bixenon yung projectors na kinabit. The headlight levelling is still functional. Yes a proper retrofit will take this long, and we have done more than 150 cars already. Pag gawa at pag latag nung wiring harness will take 2 hours already.
- Dec 2011
- 34
November 26th, 2012 05:20 AM #2458
November 26th, 2012 07:27 AM #2459
- Sep 2012
- 94
Built in turbo timer
0dometer problem
