Page 188 of 191 FirstFirst ... 88138178184185186187188189190191 LastLast
Results 3,741 to 3,760 of 3813
    Oct 2017
    #3741
    Mga boss may question ako.. Ano kayang problema nung Lancer EX 1.6 GLX MT ko? May times kasi na ang hirap ipasok sa first gear and 2nd gear. Madalas mangyari ito pag hindi full stop (sobrang bagal na, kunwari daan ng humps) then down shift sa first or second gear ang hirap ipasok. May time pa nga na kelangan ko talagang mag full stop para pumasok sa first gear. Minsan din sa umaga ganun din pero pag matagal na i-drive medyo ok na pero mabigat pa din or minsan parang may lubak (hindi smooth yung shifting).. Wala namn grinding noise matigas lng talaga ipasok sa gear.. Nagpalit na ako ng gear oil and brake/clutch fluid pero ganun pa din. Nag try din ako pa check sa casa pero sabi nung SA ayos namn daw clutch system ko saka yung shifter cables at wala daw sya maiisip na ibang cause. Advise namn mga boss kung ano pa pede kong pa check/gawin natatakot ksi ako na baka pag tumagal masira yung transmission or ibang parts na mas mahal hehe. Salamat!!
    #3742
    Quote Originally Posted by mr_makulit View Post
    mahirap naman talaga ipasok sa 1st gear pag moving na sasakyan eh. 1st gear lockout yata para di masira yun synchro. wait natin mga experts tsikooters
    Jul 2017
    #3743
    sorry hindi ko alam saan puede magtanong regarding 2016 Lancer EX GLS...nagbayad na kasi kami ng reservation fee last September 18, 2017. talaga bang 1 month ang pag gawa ng unit? possible din ba na mas tumagal pa?
    Sep 2009
    #3744
    Quote Originally Posted by pinkies View Post
    2017 is almost over, why settle for 2016 model?
    May 2013
    #3745
    Just what like ninjababez said. But, try revving it to match your speed. Should be smoother getting in the desired gear.
    Oct 2017
    #3746
    Quote Originally Posted by bugoys View Post
    I tried rev match before boss, thinking that I was not properly matching the engine's speed when doing down shifts but what happened was, when I blip the throttle, the gear did not go into 2nd gear (I was on 3rd gear) . Kelangan ko pa ibalik sa nuetral para pumasok hehe. Pero bago mangyari yung issue ko na to swabe ang rev match down shift from 3rd to 2nd gear. Then may times namn na okay sya pag may toyo dun matigas ipasok minsan di pumapasok
    Ah may gear lock out pala hehe, thanks sa info sir! So normal lang pala yun sa firs gear hehe. pero bat ganun first 2 years saken nito pumapasok naman sya sa first gear khit umaandar pa na kaunti (yung tipong usad pagong. yung speedometer eh 0 pero na-andar pa ng kaunti) ngaun lang nagkaganito.. at may times din di sya matigas at sobrang smooth? Possible na may wear out at kelangan na palitan na pyesa kaya sir?
    Jul 2017
    #3747
    Quote Originally Posted by ano727 View Post
    Yun lang kaya ng budget namin, wala naman din daw difference ang 2016 and 2017 except for facelift.
    #3748
    are they saying, they manufacture the car only when there is an order for one?
    Jul 2017
    #3749
    Hindi naman, marami daw kasi nakapila and wala daw available na unit sa dealer.
    #3750
    ah! that's most likely correct.
    despite it being a dead-end model, marami pa ring bumibili.
    i am almost tempted to get one, myself.
    the market choices today are so plentiful, it is so confusing.
    Jul 2017
    #3751
    Although tumawag ako sa ibang dealer 2 weeks ang lead time depende pa sa available na color.
    #3752
    na rev match ko 2nd gear and above, sa 1st gear di ko nalang pinipilit lol
    #3753
    i like that word, "depende sa".
    it helps absolve them of their... in-accuracies.
    my personal advice to myself is, "don't rush. and don't believe their sales talk, until the keys are in your hand".
    Oct 2017
    #3754
    Haha lol. Cge boss ninja, boss bugoys salamat sa pagsagot.nice to know na normal lang pala tong akala kong malaking problema hehe. Salamat!!!
    May 2013
    #3755
    Sir, you are not revving hard enough. Hahahah. Or get a second opinion, if it really bothers you.
    Good luck.
    Mar 2017
    #3756
    Hello mga tsikoteers! I am new lang po hehe so pls bear with me. So eto na nga, next yr. I have plans on buying 2nd hand ex after i graduate pero I have so much combination of some factors in mind. Well first I want an ex that is so much engaging to drive which would be manual, also I want it to be in such average fc not high not low but just average.
    With that said I am leaning to lancer ex 2.0 gt, but since that gt variant is phased out, may makikita pa kaya ako neto? And if so is the gt worth it. Or will the gta do the trick on the factors mentioned above well siguro in this case not manual pero andun parin yung enjoyment ng driving?
    Jun 2017
    #3757
    Pa check mu gear synchronizer. Baka needs new set.
    Let me know how it goes.
    Nov 2017
    #3758
    hi, bago lang ako dito tapos gusto ko lang malaman kung worth it ba mag change ng stock rotors to either big brake kit or same size ng stock rotors pero naka ventilated at crossdrilled rotors lang para sa 1.6 EX ko :D
    Nov 2017
    #3759
    Quote Originally Posted by carmellolo View Post
    Hi, meron kapang makikita po na mga 2.0 GT na for sale ngayon hehe. At for me, mas maganda naman kapag 2.0 GT kunin mo kesa 2.0 na GT-A. Mas maka enjoy ka sa manual na 2.0. Tapos regarding ng FC nasa average naman ang 2.0 na GT.
    Nov 2017
    #3760
    Hello po,
    question lang po. I'm planning to buy a new 2017 gls m/t lancer ex. I am concerned with the maintenance cost and parts availability. How is it po?
2008-2013 Mitsubishi Lancer EX GLX / GLS / MX / GT / GTA [continued]
