Page 187 of 191 FirstFirst ... 87137177183184185186187188189190191 LastLast
Results 3,721 to 3,740 of 3813
    Dec 2016
    #3721
    'yan ang used car na masarap bilhin!
    Onga.. kaya di ko na pinalampas. :D
    Dec 2016
    #3722
    Question po:
    Ano po headlight bulb ng EX-GTA? sorry noob lang po.
    Ano magandang alternatives?
    #3723
    Quote Originally Posted by lextaicho View Post
    Question po:
    D2S 35W.
    No other alternatives since that's an HID bulb. You can get cheap China replacements or more expensive Philips/Osram HID bulbs.
    Aug 2012
    #3724
    You can upgrade from stock HID to Osram Cool Blue Intense Xenarc D2S (this is what I use) or Osram Night Breaker Xenarc D2S. Both have similar brightness, just different color temp - Cool White vs Warm White.
    I wanted to get Philips X-treme Vision D2S but is more expensive.
    Sent from my ASUS_Z010D using Tapatalk
    Dec 2016
    #3725
    Quote Originally Posted by red_one View Post
    thanks...
    another question..
    how about sa fog lamp bulbs... ano po magandang replacement? for much brighter output yet safe...
    and ung turn assist light natry nyo na din mag palit?
    Mar 2004
    #3726
    Hello everyone,
    Tanong ko lang kung may mga naka experience na sa inyo ng kalampag sa likod ng lancer niyo. Sabi kasi dun sa Mitsulancerph na forum (na mukhang nagsara na) ay common daw eto sa mga lancer ex. Yung 2012 Ex MX ko kasi, marami na akong pinagpacheck up an (casa, servitek, etc.) at pinapalitan ko na ng shock absorber pero nandun pa rin ang kalampag. Sabi dun sa forum at brake caliper daw eto.
    Sa mga nakaranas na nito, saan kayo nagpagawa?
    Maraming salamat po sa mga sasagot.
    May 2017
    #3727
    Quote Originally Posted by sups View Post
    sir ilan taon na lancer nyo?mag ttwo years na ang lancer ko..last month hindi din gumagana ang am ng radyo ko...dapat pala madala ko na din sa casa para mapalitan na..11km pa lang naman tinatakbo ng kotse ko..buti na lang may nag post dito..
    MODERATOR'S NOTE:
    Original thread can be found here:
    404 Not Found
    bos patulong ako. biglang nag blink N ko while driving ako (D). Medyo humina din hatak. i'm driving MX 2001 model. thank you
    Aug 2012
    #3728
    thanks...
    another question..
    Fog lamp bulb is H11. If you want halogen, you can get Philips Vision H11. If you want LED, you can get Philips ZES H11. Both are plug and play so you just replace the bulbs. No wiring change.
    Dec 2014
    #3729
    Good afternoon mga boss!
    I have this Lancer EX 2014 model, is it okay to post my problem here? Anyway. Ang problem ko is yung Radio and LCD screen ko. Doesn't show anything at all as in itim na itim, tapos yung switches nya naka ilaw lang then wala ring tunog radio. Pag pinapatay ko yung makina ng car ko naka ilaw pa rin yung switches sa radio. Ano po kaya problema? Tinry ko i disconnect yung power sa batt tapos on ko uli same problem pa rin sya. Anyone help me please? Thanks in advance!
    May 2017
    #3730
    Quote Originally Posted by oliver1013 View Post
    Nga pala nagpalit ako battery kanina, paalala sa inyo pag nagpalit kayo, bantayan niyo yung nagpapalit kasi kailangan alisin yung vent ng air filter..bushet yung motolite guy pinuwersa yung turnilyo na nagkakabit ng vent sa grill, e plastic clip yung na may plastic na turnilyo ayun na lose thread...tender loving care lang yung basta dahan dahan.
    May nabibili ba nun clip na yun? sira na kasi yung isa ko..
    Sir question lang bago ka nagpalit ng battery, may nakuha kang error indicator na battery maintenance required? sa akin kase meron pero lumalabas lang pag umuulan at napadaan sa mababa na baha. medyo magulo cya
    Dec 2016
    #3731
    Quote Originally Posted by Andoy View Post
    Hello everyone,
    Yung sakin, parang may kumakatok sa likod pag nalulubak... baka same prob? tingin ko di naman sa shocks.. kapaplit ko lang din ng shocks and springs KYB Lowfer + Eibach Pro....
    Dati wala naman un... naoobserve ko lang lately.
    Jul 2012
    #3732
    naobserve ko din to sa 2013 model ko, pagnagbrake, may knocking sound. pero isang katok lang, haha. usually pag dinadala ko sa casa, nawawala , tapos after a while bumabalik din. ngayon naman, pag nag hand brake, saka ko naririnig.
    guys, i'm about to change tires din pala, ano ba mga pinalit nyo na tires? yung dunlop sp sport 2050 pa din ba? sa mga nag try sa iba, medyo mas mahal din kasi yung dunlop. nag check ako kay yokohama, Bluearth Ace AE50 lang ang kasya for 205 60 R16. mas mura kesa sa dunlop. mas mura din yung dunlop sport LM704.
    #3733
    Quote Originally Posted by bangfranz View Post
    sir, kung ito po at same HU sa 2013 MX ko at covered ka pa ng 3 yr warranty, punta ka na lang sa casa. They changed mine without a question dahil common problem yang HU ng Lancer EX (at least I'm referring dun sa HU na touchscreen kasi yung GTAs naman at alam ko Rockford yung mga yun). Yung HU ko eh tumigas ang touch screen while 18 months old pa lang si MX. Ayun palit HU. eto 49 months old na si MX ko, ayos naman si HU.
    BTW, nawala na ba talaga yung mitsulancerph forum?
    madami resources dun regarding kapampag etc ng MX dati kasi.
    Jul 2017
    #3734
    Quote Originally Posted by maillot jaune View Post
    oo nga sir ano nga ba nangyari doon? hehe
    anyway, sakin sir 2013 GLX, simula noong pagkabili hindi ko pa tinanggal yung plastic na parang screen protector sa HU. then earlier this year ayaw na mapindot. kahit tinanggal ko na yung plastic cover
    ayaw pa din. sira na talaga kahit hindi masyado nagamit. pati yung cover ng SD Card, dapat hindi sya nahuhulog pag binuksan kasi may parang rubber na nakahold sa kanya sa HU, lumutong din ang rubber
    kaya tinabi ko na lang ang cover na yun. ganun yata talaga ang stock HU from winterpine - built to last within the warranty period only.
    ano kaya pwede i-replace sir? yung sa growl audio okey kaya yun?
    Jul 2017
    #3735
    Quote Originally Posted by turnpike View Post
    meron din sa goodyear sir. assurance triplemax nasa 3k plus yata yun. forgot the exact price kasi nag inquire lng ako at di pa nakabili.
    how much yung nacanvass mo sir & where?
    may tusok malapit sa sidewall ko kaya napilitan ako bumili in a hurry last year ng lm704 sa dunlop magallanes. 4,7++ yata yun.
    Feb 2011
    #3736
    Good Evening,
    QQ: Meron po nagbebenta ng evolution X OEM wheel sa OLX ngayon was wondering if my fitment issue to sa stock tires ng gta?
    18x8.5 on a 215.45.r18 a10s
    Jul 2017
    #3737
    Good Evening,
    Mga sir sn pano install oem sub ng gta sa mx 2013.. tsk ung audio control. Salamat
    #3738
    Need both ABS sensors for the left side. Aside from casa, anywhere else I can get them cheaper? Kahit hindi OEM, mawala lang yung CEL. Reparir shop reco na din would be nice. Thanks in advance.
    Aug 2017
    #3739
    Mga Sir.. advise naman mga papi..; san po kya ako makaka bili ng Fuse for lancer EX? mukhang fuse ang sira ..kasi hindi na gumagana cigarette outlet ko.. and also san po mura makabili ng "Super Long Life Coolant (SLLC)" . ano ba sir pingakaiba nung 30/50 premixed and 50/50 premixed?. newbie lang po sir.. thank you po...
    #3740
    Quote Originally Posted by sd18 View Post
    the fuses are ordinary, po.
    any adequately-stocked auto parts store should have them. bring yours for comparison, as there are at least two sizes. and be mindful of the color. color-coded sila (vis a vis amp rating).
    if in doubt as to the quality of coolant, buy from the casa, po.
    simply put, the 50/50 is more matapang than the 30/50. how this figures in our country, i do not know.
    if you have the car manual, these info should be there. it also shows where the fusebox is, and which fuse corresponds to what appliance. some fuse boxes may also show which fuse is for what appliance.
2008-2013 Mitsubishi Lancer EX GLX / GLS / MX / GT / GTA [continued]
