Results 1 to 9 of 9
    Dec 2009
    guys ask ko lang. balak ko kasi bumili ng 2nd hand step board for my 2011 adventure. the problem is nung may nakita ako ang sabi drill daw or welding para ma install yung step board. since may warranty pa yung advie ko. mawawa ba warranty pag ni-drill or welding yung step board? thanks!
    if sooner (hwag naman sana) na may nakita o nireklamo kang defect or sira that was caused or partially caused by the drilling or welding process, hindi honored yung warranty mo.
    but since tingin ko naman, sa body or sa chassis i drill yun, malamang ok lang yun.
    di ko sure ha.... check natin ibang experts dito.
    Mar 2011
    [QUOTE=guys ask ko lang. balak ko kasi bumili ng 2nd hand step board for my 2011 adventure. the problem is nung may nakita ako ang sabi drill daw or welding para ma install yung step board. since may warranty pa yung advie ko. mawawa ba warranty pag ni-drill or welding yung step board? thanks! [/QUOTE]
    welding or drill???WAG bos.....welding weakens the steel di ba...bat di pa yung bolted or yung may bracket ang kunin mo.anytime mo gusto tanggalin,madali lang...also if bibili ka ng 2nd hand na welded, ndi na matibay ang plates or bracket nun....even mga auto shops ndi nagrerecommend ng welded type...they are only selling those type dahil yun ang options ng buyers na naghahanap ng mura...pero kahit sila, they prefer the bolted one.
    Dec 2009
    Quote Originally Posted by amir1223 View Post
    oh no.. nakabit na yung step board ko. wala kasing bracket yung step board kaya gumawa sila ng bracket. winelding nila dun sa may chasis. inaalala ko nga baka kalawangin yung bracket kaya balak ko papinturahan + undercoat nadin. inaalala ko lang kung void na yung warranty
    Sep 2006
    may recommended brand/type ng step board po ba kayo para sa adventure? Saan po ok bumili at magpakabit at magkano po kaya?
    Jul 2012
    Quote Originally Posted by radz15 View Post
    my advise, wag na kabitan ng step board... wala naman pag gagamitan yan IMHO
    yung sakin step tube... ampanget kase nung mga step board sa banawe sobrang ninipis parang pag nasagi punit na. Plus step tube can be repaired kase stainless lang sya pde i bend or pukpok. It is very usefull kse dun ako umaapak pababa. instead na gamitin ko yung running board. Di maganda yung welding source yan ng kalawang, Yung sakin nag fabricate ng harness puro bolt on lang walang welding... Katamaran lang kase ng nagkakabit pag welding
    Sep 2006
    Sir Japeeps, pwede po ba pa-post ng picture nung step tube nyo? Tsaka magkano at saan nyo po pinagawa? TIA!
    Apr 2013
    Up on this
    Quote Originally Posted by japeeps View Post
HELP bout sa step board for adventure
