Results 21 to 30 of 42
- 10,620
November 4th, 2005 03:26 PM #22
wala pa po sa area na yan, probably next year sila magstart for nationwide coverage
- 10,620
November 4th, 2005 03:30 PM #23actually dati meron na i know someone who has it.
kaso nung nag apply ako wala na raw.
baka siguro next year nga ulit.
November 4th, 2005 03:39 PM #24
what i understood sa e buy n cell was suspended muna ang bagong mga linya (?) when can we start using this service?
November 4th, 2005 05:22 PM #26
sa manual may nakalagay duon sa paglalagay ng CDMA antenna, i just donw have an idea where to get those antenna
November 4th, 2005 07:34 PM #27Originally Posted by jedi
This type of antenna is used mostly for scanner radios, where a wide-band antenna is most useful. But before you go out and buy one, make sure that you can buy an external antenna connector (at the end of the cable) of the same type needed. Kung walang mabili na discone, pwede namang gumawa niyan ... you can use fine wire-mesh or plain metal sheet instead of the whips in the picture - mukha siyang cone with a plate on top. And since you're only interested in CDMA, pwede pa siyang mas maliit (1.9GHz being the lower limit) ... when in comes to wavelengths kasi, the higher the frequency the smaller the length is. Below is an example, but not necessarily of the same size.
November 5th, 2005 01:48 AM #28Originally Posted by jedi
November 5th, 2005 09:41 PM #29
yung mobile unit naglabas na sila before, may sample pic dito
http://www.ebuyncell.com/forums/show...&threadid=1042
pero nakahold daw for the meantime, may new unit daw silang ilalabas
Tsikot Member Rank 4
- Oct 2004
- 2,315
November 5th, 2005 10:28 PM #30ok ito para sa mga telebabad pips. Sana nga pwede sa cars at pwede lagyan nalang ng mga antena mga cars para sa signal
