Page 18 of 24 FirstFirst ... 8141516171819202122 ... LastLast
Results 341 to 360 of 474
    Hmmm curious, what's the difference of end result of a front load vs a top load?
    Front load uses less water than a top load.
    Front load does not twist clothes. It tosses them around.
    Also, hindi masyado babad sa tubig ang damit kasi less water and by tossing them around mas less wear and tear… imho
    #342
    Hi bro. Laba expert hehe
    Aug 2004
    #343
    Haha. Back to popular fabric conditioner muna ako bro while the dryer is not working. Kontra hamog sa sampayan maulan kasi lately.
    Kakagaling lang ng LG tech. Replaced inlet valve and pressure switch. Same banana. Balik daw sya next time to replace the drain pumps. Last na siguro to. If that doesn't fix it then maging washer na lang to and we will be getting a separate dryer. So far only paid 450 for the initial diagnosis. They already tried a new computer board before.
    Sent from my SM-A605G using Tapatalk
    #344
    Same brand parin detergent mo as before?
    Kaya i prefer separate yung washer and dryer if space is not an issue.
    Aug 2004
    #345
    Same brand detergent. Mura kasi hehe. Yung fabcon lang ang nakastock muna until the dryer is fixed.
    #346
    This is from you tube. Hindi kasama yang splitter na yan. Pero yung silver na yan na nakakabit sa gripo yun ang connector. As you can see you will need a small flat head screw driver, then yang hose na nakabit sa silver eh detachable from the silver. Kung gusto mo gamitin yung gripo detach mo lang yung hose ng washing machine from the silver. Madali lang detach at attach yung hose ng washing machine.
    I suggest you buy a Teflon tape para to use between the faucet and that silver connector para sure na walang tulo. Attachment 39180
    Thanks! I think I will buy Panasonic na talaga because this model has a lot of youtube reviews din
    Yes you can use the faucet too. The knob on the side is the one to control the on for the washing machine. The knob on top is the one fot he faucet naman. Yes your all aound can easily do it.
    1. turn off main water valve
    2. remove the old faucet using a monkey wrench
    3. put new faucet with teflon tape para walang tulo
    4. turn on main water valve
    Tada! You're done
    Great! Kayang kaya ng all around namin yan
    Nasa 1 meter (maybe less) lang ang kasamang hose ng washing machine.
    You'll need to extend it with a garden hose o kaya bili ng mas mahabang washing machine hose from Shopee. Mas malinis tignan kung bagong hose na pang washing machine pero pwede namang i-dugtong lang sa garden hose with the proper fittings.
    The drain hose is another issue. Kung walang drainage hole na katabi ang washing machine, dapat i-extend (again, Shopee) para hindi magkakalat ng tubig sa paligid ng machine.
    Power cable hindi rin ganun kahaba.
    I'll take note of that! Thanks for the suggestion! I will need both washing machine hose and drain hose
    Quote Originally Posted by gongrhey View Post
    Meron kaming Panasonic automatic top load dyan sa Pinas. Di kami satisfied kasi ang bagal ng ikot parang di nalalabhan ang damit. Whirlpool front load automatic naman ang gamit ko dito sa AE for 6 years walang sakit ng ulo.
    Ganito ang faucet namin sa washing machine.
    Attachment 39184
    I saw that at shopee! Will buy that
    Ayusin ko muna problem namin sa ref before I buy washing machine
    Aug 2004
    #347
    Bought a Whirlpool 8kg dryer last Saturday. Tambak na kasi labada and amoy kulob na.
    It dries faster and better than the LG 2in1. Clothes come out fluffier especially towels. It doesn't drain the lint down the drain. It also has shoe drying rack. A nice bonus is the light inside the tub that comes on when the door is opened.
    It doesn't have any networking capabilities though so I had to move one of my wifi cameras to keep an eye on it. It's also a bit noisy.
    So far so good. I was able to do around 5 loads yesterday: wash/rinse/spin on the LG then dry on the Whirlpool. Their doors open on opposite directions so since they're side by side it's just a simple bend and twist to move clothes from one machine to the other.
    22k? thanks for the review. iniisip ko saan pwede ilagay
    Aug 2004
    #349
    25k+ SRP tapos 10% off SMAC.
    May mahabang corrugated duct syang kasama to vent the hot air out. The outlet is at the back. You will need to factor that in also. Aside from that power cord lang ang external appendage nya.
    Aug 2004
    #350
    So it looks like the LG is finally fixed. LG tech already replaced the board, inlet valve, and pressure switch with brand new parts. None worked so the tech pulled them out and reinstalled the original parts. He then replaced both pumps and we ran a test load. Looks like that fixed it. I was about to give up and just use it as a washer/spinner but it's good to have it back at 100% as a backup dryer.
    OEM parts were surprisingly cheaper than those available online. Labor is understandably high but I still paid less than what I already spent trying to fix it myself.
    Kudos to LG PH for not giving up. Tech was happy to close 8 tickets including mine yesterday. Problem is he still has 41 left
    Mar 2021
    #351
    What’s a good brand of dryer?
    Anson’s has a one day sale tomorrow which includes Beko, Electrolux and Panasonic
    #352
    Sale online or physical store?
    Mar 2021
    #353
    Online sale
    1 Day Online Sale. | Ansons
    Aug 2004
    #354
    One shouldn't judge a book by its cover pero some below 20k units like TCL and Whirlpool have plastics that feel like Orocan.
    Electrolux and Panasonic MIGHT have local support. Beko not sure.
    You won't need an inverter dryer.
    #355
    Online sale
    for some reason,
    some important features of some of the items, potential deal-brakers they may be, are not mentioned.
    the dimensions.
    Mar 2021
    #356
    Malaki pala discounts sa sale ng Anson’s
    Aug 2004
    #357
    Pwede na yang Panasonic at 20k. Free delivery?
    Mar 2021
    #358
    Yes free delivery with most appliances
    For dryer meron two type, condeser and air vented dryer… me preferrable the condeser type.. install anywhere…
    air vented advantage if sa labas ang dryer or you have existing outlet if put it inside the house…
    Jun 2008
    #360
    Hindi tumagal samin yung electrolux front load i think 3 or 4 years lang. Mahal ipagawa.
Please suggest washing machine.
