Not sure, have a look at the back side near the drain port(hose barb) You dont need to remove the solenoid, but there could be a service port to clean the open/close valve. That service port could be leaky
The black circle isn't it a gasket? that needs replacement? I have to check tomorrow where the leak is coming a bit hard to check since it is a the bottom. If leak worsen I have to call samsung henry's I just hope that it can be easily fix.
