Results 1 to 13 of 13
    Has anyone installed one in P.I.? How much did it cost? I will be using my mom's garage and what she has are manual roll up doors. It's a 2-car garage converted to a leased space with 2 x 4 meter wide slots. I will be using 1 slot only. I checked in olx and what they have are 3 meter wide sections. This is actually ideal for me since I can have the 3 meter section as an automatic garage door then put a small 0.7 meter (standard small door width? not sure) access door at the side.
    Sent from my SM-G920F using Tapatalk
    Yup meron. P150k good for 2 cars side by side na medyo masikip. I can give you contact number if you want.
    Sep 2014
    Wag ka na sa olx fafa yebs, halos lahat upscale malls ngaun mga tenants automatic roll up door na.
    75-95k yung mga nacontact ko for a 3 meter width x 2.5 meter height door. Tama sabi.mo Cathy 150l for 2.
    I also talked with 1 na kayang i-convert yung existing manual roll-up door. Antay ko mag inspect for a quote. Meron na kasing manual roll-up door. Inalala ko lang si misis di niya kaya i-open yun kasi.
    May 2007
    I am interested in this automatic roll-up garage door. Pa-share naman po ng contact nos. ng good installers and yung feedback niyo po if any. Thanks
    Sent from my MI 9 using Tapatalk
    Sep 2008
    Anyone here have an automatic garage door? Can you share pros and cons including maintenance cost. More or less, how much did it cost you for installation?
    Feb 2014
    Quote Originally Posted by jakewise View Post
    i'm considering a sliding gate opener. just concerned about security coz the "locked" position probably isn't secure enough
    Sep 2008
    Quote Originally Posted by Vodka View Post
    I believe you could always have an additional barrel lock in place during night time when all vehicles have parked already for added security
    Automated sliding is more durable & more secure than swing. Where conditions permit, a number we've done had 1 leaf in manual swing while the other is auto-slide. Width of each leaf should ideally be wider than that of SUVs.
    Sent from my SM-S901E using Tsikot Forums mobile app
    Sep 2008
    you do install sliding garage doors?
    Only do basic design/specs & work w/ a proven specialist for R&D & execution for those. Recently did a neat 2 leaf same-direction slide w/ a concealed 'follower' system due to space limits that couldn't accommodate 1 long gate.1motor pulls to open/close both panels.
    Jan 2012
    Sliding is far more reliable than swing, especially for wide spans.. Avoid bi-fold gates as much as possible as it eventually sags. Con for sliding is that it needs to be perfectly level at the track and debris need to be cleaned from the track once in a while.
    Im doing a detail for a telescoping sliding gate now, its vastly more complex than a single panel sliding gate, also im concerned about the speed
    Quote Originally Posted by viper888 View Post
    Did the telescopic w/ covered side mounted cables & pulleys recently. Works like a charm. Just need to be precise w/ plans & execution to have vertical stiles aligned how you wish them.
    The tracks, solid round rod would be smoothest...add along a self draining/cleaning mini trench(red arrow) to catch/drain water at the ends & out the driveway. 20230730_113528.jpg
Automatic garage door
