Results 1 to 20 of 38
    Mar 2004
    Planning to buy a multimeter / multitester ... need basic device to test for current / electricity ... can buy something more expensive for future-proof if price difference isn't that much ... only used occasionally (2-3 tines a year) ...
    So far, found these two best sellers on Shopee ... an electrician mentioned something about an analog and digital model ...
    https://shopee.ph/Ingco-Original-LCD...362.5058706694
    https://shopee.ph/LCD-Digital-Multim...8-67bdd025c77a
    Suggestions please ...
    they probably will fit the bill.
    my main concern is the weight.
    for me, the heavier, the nicer. para hindi nahahatak when working.
    i have both the analog and digital variants. i personally like the analog, probably because it's what i was brought up on.
    compared to yesterdecades,
    today's multimeters are much cheaper, but just as accurate and reliable. even the cheap ones.
    lucky, this new generation.
    our old meters were sanwa and before that, an american brand i forget...
    Feb 2014
    【ANENG 】LCD Pocket Digital Multimeter Backlight AC/DC Automatic Portable Voltmeter | Lazada PH
    this one looks a lot better. auto range. backlit. i think i'll buy this later even if i already have several slim multimeters my favorite so far is UNI-T UT120
    avoid the fat clunky ones w/ the noisy selector dial
    don't get analog
    get model that beeps on continuity
    Jul 2004
    Yung binili ko sa Shopee na mura, nasira kaagad after less than 2 months
    Ended up buying a "pricier" one found in the hardware store. Brand is Newstar. It is now 6 months and still working.
    I'd go with a known brand, leads are protected in the case too.
    https://shopee.ph/Sanwa-Cd800A-Digit...6-1bfc625b7e2e
    Jan 2009
    You can't have enough...
    I have two Sanwa analog multimeters (the other is in the office) and three DMMs.
    99% of the time, I use the DMMs, as they have more functions than the Sanwa.
    If you have an analog multimeter, always park the selector at the highest AC Voltage range (1,000 V AC in this model) when not in use. Don't leave it in resistance mode or current mode or you burn it up (lucky if you just pop the fuse) if you or someone else accidentally measure high voltage with it. You actually need those extra brain cells when using this. ;)
    Mar 2004
    Quote Originally Posted by Vodka View Post
    How's quality of UNI-T? ... will probably get this ... UT123 ...
    https://shopee.ph/UNI-T-UT123-Pocket...362.4212932764
    Feb 2014
    uni-t better than aneng but anengs aren't bad either
    that ut123 is too basic. lacks too many features
    better get the M118A posted by gearhead
    Jan 2009
    Found this on the web. Not the exact models but any way you look at it, the accuracy on these things are pretty good enough for general use.
    Source: UNI-T UT136B and Aneng AN88 - Page 1
    Mar 2004
    Basic is all that's needed ...
Multimeter / Multitester suggestion.
