Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
    Jan 2009
    #21
    Quote Originally Posted by Vodka View Post
    i like cheap measuring devices
    any recommendations for a cheap DC clamp?
    btw that aneng doesn't have capacitance coz it's super cheap can't recommend it coz LCD contrast is poor. i might buy the backlit one and give this away to someone
    btw2 in case anyone is wondering, the bottom left is a laser tach
    I try to steer away from minimalist "pocket" DMMs with non-removable probes.
    My clamp meter is an Aneng ST-209. It does both AC and DC current measurements (600A max).
    #22
    Cool feature, bro. What are the ranges for the DCA?
    Jan 2009
    #23
    60A and 600A
    60A range has 0.01A resolution
    600A range has 0.1A resolution
    Feb 2014
    #24
    ST194 seems to be very similar but w/ button mode select instead of mech dial. might get this one...
    Jan 2009
    #25
    Good plan. Just make sure you get the ST194... the ST193 is identical in every way, except that it doesn't have DCA measurement capability.
    Feb 2012
    #26
    I actually had been using an Aneng multimeter too - the Aneng M118A.
    I picked this one for the size, being backlit, auto-ranging, flashlight function and of course, the price.
    I haven't recommended it though as it feels quite cheap, although for my purposes it fits in really nicely.
    Some may want the feeling of pride and confidence in using a more heftier, better built one.
    Jan 2009
    #27
    If you work in high-tech industries such as telecoms, electronics, space, etc. you undoubtedly need proper instruments to do measurements. The video I posted earlier in this thread explains why.
    But for the casual DIY'er or enthusiast who just needs a way to do go/no-go or good/bad component testing, these cheap meters are excellent for the money.
    For example, if a 15uF run capacitor reads 15.23uF on one meter and 15.31uF on another, the small discrepancy doesn't matter. The capacitor is good!
    #28
    60A and 600A
    10mA resolution... "Good enough" to check standby current of connected devices - Central lock, alarms, etc
    Mar 2004
    #29
    【ANENG 】LCD Pocket Digital Multimeter Backlight AC/DC Automatic Portable Voltmeter | Lazada PH
    this one looks a lot better. auto range. backlit. i think i'll buy this later even if i already have several slim multimeters my favorite so far is UNI-T UT120
    How's quality of UNI-T? ... will probably get this ... UT123 ...
    https://shopee.ph/UNI-T-UT123-Pocket...362.4212932764
    Feb 2014
    #30
    uni-t better than aneng but anengs aren't bad either
    that ut123 is too basic. lacks too many features
    better get the M118A posted by gearhead
    Jan 2009
    #31
    Found this on the web. Not the exact models but any way you look at it, the accuracy on these things are pretty good enough for general use.
    Source: UNI-T UT136B and Aneng AN88 - Page 1
    #32
    Source: UNI-T UT136B and Aneng AN8??8 - Page 1
    Thanks for sharing bro... Very good accuracy...
    Pero sa regular na gamit natin pwede na +/-5%... He he he
    Mar 2004
    #33
    Basic is all that's needed ...
    Feb 2014
    #34
    yeah basic is all you need until you wanna test the starting capacitor on that household appliance that you need to work asap
    Jan 2009
    #35
    Yepp.
    I recently purchased a used 0.5HP A/C and I noticed that both the compressor and fan were humming loudly in operation. Took this cap off.... It's a 15uF (Herm) and 3uF (Fan). The spec sheet called for a 20uF + 1.5uF. Replaced the cap and the A/C is now quiet.
    #36
    Yepp.
    Now, that's desirable and oh so cool....😁
    Mar 2004
    #37
    Will just buy another one ... for now, have no skill to fix appliances ... just mostly test for continuity ... once or twice a year ...
    Mar 2004
    #38
    Wow, you guys are really good ... right now aircon compressor is vibrating loudly .. and the technician could not even fix it ... it's a 15 year old backup air conditioner ...
    Thank you everyone for the suggestions ... hope this forum will continue or move on to another platform ... along with the members ...
Multimeter / Multitester suggestion.
