We've had problems with sediment buildup in our pipes and is affecting water flow and clogging up faucets, shower heaters, and toilets. All our pipes after the water meter are PVC, so the sediment is coming from the water supply (Maynilad), especially after a low water pressure incident.
As such, I 'think' I need some sort of
basic sediment filtration to be installed somewhere in our house plumbing.
My questions are:
1. What type of filter do I need for this use case? Micron rating? Flow-rate rating? The less maintenance, the better. We will NOT use it to drink from.
2. Where is it typically installed, A, B, or C? (see diagram)
