Results 1 to 10 of 38
September 28th, 2017 06:34 PM #1
Saan i-tapped yun 2 wires na lumabas sa wall?
September 28th, 2017 07:00 PM #3
So doon sa "Power" i-tapped? Tapos ang maging switch itong timer na? If i want to used the existing switch I tap mag jumper na lang ng two wire para doon sa "switch"?
Baka sumabog nanaman parang yun outlet sa Kitchen dati. [emoji23] patay nanaman ako.
Sent from my iPhone using TapatalkLast edited by shadow; September 28th, 2017 at 07:04 PM.
September 28th, 2017 07:09 PM #4
September 28th, 2017 07:17 PM #5
Disregard the photos in my first post.
Saan i connect yun dalawang wires coming out from the wall? Doon sa "Power" or isang wire sa "Power" then isang wire sa "switch"?
*cvt dito ka reply.
Wala naman mangyayari diba kahit madikit ko yun wires ng switch iilaw lang siya unlike wires ng outlet sasabog
Sent from my iPhone using TapatalkLast edited by shadow; September 28th, 2017 at 07:27 PM.
September 28th, 2017 08:39 PM #6
Sorry bro. I was driving.
Connect the two live wires on the terminals marked as "power" in the picture.... And then the other two wires going to the appliance on the terminals marked as "switch" in the picture..
You can test... Connect the two live wires on the terminals marked as "power"... And then connect two wires from the bulb to the terminals marked as "switch" in the picture.. If the timer turns on , -the bulb will light up... If the timer turns off, the bulb will turn off..
(The switch in this picture is now double pole double throw... Vs your first picture which is single pole single throw)
What appliance are you connecting?Last edited by CVT; September 28th, 2017 at 08:50 PM.
September 28th, 2017 08:43 PM #7
Paano pag hinde sa appliances gagamitin? Celing light lang gusto ko gamitan? So yun dalawang wires from the wall sa power siya and not one wire on power-one wire in the switch? Bale ito na magiging switch instead of the regular light switch Diba?
September 28th, 2017 09:16 PM #9
Bro ceiling light, mas okay iyong first picture dahil 1 wire lang dumaraan sa light switch... So single pole single throw dapat.
Yes, that would replace your light switch...
Again okay lang kung 110v AC makuha mo na timer switch... It will work here... Bababa Lang ang power rating, but it does not matter because the load is only lighting...Last edited by CVT; September 28th, 2017 at 09:19 PM.
Heard through the grapevine that the Atto 2 is going to be released next. The most likely date is...
BYD Philippines
