Results 1,141 to 1,150 of 1411
- Mar 2013
- 6,160
October 17th, 2020 11:06 AM #1142
Good wishes. Tricky to have large borderless panes to functionally open & require a good seal. This definitely won't fall on the usual upscale ballpark. Glass, insulated you'll want, & AC alone will be way way up there. And wood...that has long become a luxury...whatever species, always go treated.
- Mar 2013
- 6,160
October 17th, 2020 11:17 AM #1143I guess i can compromise on the glass for the cost, toughness and weatherproof properties. Since we do have typhoons and earthquakes here. Thought about that a lot. But ideally would still be very large unbroken panes.
My view faces the morning sun so thats a bit better for aircondition requirements.
Triple pane glass in the bedrooms for maximum sound insulation.
Sent from my SM-N975F using TapatalkLast edited by EQAddict; October 17th, 2020 at 11:19 AM.
October 17th, 2020 11:17 AM #1144
Hindi ba mainit yun mga ganyan wall to ceiling glass wall? Pansin ko kasi sa mga condo na ganyan ang design ang init kapag tirik ang araw Parang mga green houses?
Sent from my SM-N950U using Tapatalk
October 17th, 2020 11:19 AM #1145
I think medyo high maintenance ang glass kitang kita yung mga alikabok na nagbibuild up kaya dapat laging nililinis. Okay kung isang floor lang pero kung may taas, dapat accessible din para sa maglilinis.
- Mar 2013
- 6,160
October 17th, 2020 11:26 AM #1146Will use insulated glass (triple pane for bedrooms and double pane for living) and will have curtains or blinds to help with the heat.
Will make sure there is cross ventilation (sa condo walang cross ventillation).
And the house faces the morning sun so not too hot (though still heat will be an issue). Roof and eaves length will help mitigate.
As for glass cleaning....maybe once a year lang naman needed to clean haha. But i have experience cleaning the glass in my existing house....newspapers are the best for cleaning.
October 17th, 2020 11:35 AM #1147
Yes...Insulating glass can cut the heat, but the tropical advantage & envy of having the hilltop breeze in & out must be tapped. Then, we've the mosquito factor...many deny their welcome via view-spoiling screens, which defeat the clean look aim....It's really gonna be a balancing act for function & form.& Yes. Though up there lonesome, w/o neighborhood construction & vehicular traffic, dust & pollution will be significantly less. Still, it will call for maintenance & cleaning.
October 17th, 2020 11:37 AM #1148
You will need a higher capacity aircon to cool your room with 4.5m ceiling.
Signature
October 17th, 2020 11:45 AM #1149
October 17th, 2020 11:50 AM #1150
VinFast VF 3
