Results 751 to 760 of 1411
- 54,216
February 23rd, 2019 09:45 AM #751have you considered hiring more mixers, so's everything can be finished in one day?
i'm no engineer, and i do not have any idea on whether such one-day adventure is structurally acceptable.
i'm just looking at the time aspect.
February 23rd, 2019 10:28 AM #752
Yes doc, the cost would just come near the ready mix option and not worth the additional effort
Sent from my Mi A1 using Tapatalk
February 23rd, 2019 11:58 AM #753
What's your volume & manpower load? Monolithic pouring is always better than 1 w/ breaks & splices. Try searching a portable rental pump.....or Doc's idea. These reduce time & effort. For 1 bagger mixers, focus on mix consistency esp water content. The lower, the better.
If you can't do the 1 go option, discuss w/ your structural designer & pre-identify the cut sections. He'll point those w/ the lowest stress & moment exposure.
Check the forecast, choose a comfy non-rainy day, or better....do the pour from dusk to dawn (more about temperature than traffic). Temperature significantly affects concrete curing and ultimately its strength. Too hot? You'll get a hastened & uneven cure start where water loss is abrupt. This causes cracks and weak points.
Pouring is a critical activity. Think no going back once done. Quality must be primary, cost secondary.
- Nov 2017
- 1,748
February 23rd, 2019 03:04 PM #754
- Nov 2017
- 1,748
February 23rd, 2019 03:06 PM #755https://www.*******/item/portalift-p...l?h=c6c33ba53f
February 23rd, 2019 06:29 PM #756
Thanks Sir Max, I was able to get a small truck provider, I was surprised that the cost per cum is P5,500. I was expecting P3,500 as are most posts at olx. The manual pouring by section by my estimate is P3,500 max. But the last sentence of Sir Travs really got into me, so no choice but to go ready mix [emoji2]
- Nov 2017
- 1,748
February 23rd, 2019 09:29 PM #757
February 23rd, 2019 10:13 PM #758
Sir Max, pump crete is 15k + mix of 5k/cum for a total of 25 cum max my estimate, ganito na ba talaga ang going rate o baka dumaan ako sa agent kaya masyadong malaki?
February 23rd, 2019 10:41 PM #759
February 26th, 2019 03:41 PM #760
Guys quick question. Is there really a surety bond to be paid to DPWH for altering the top of their drainage into a ramp?
They're asking for what seems like 20-30% of the cost of the drainage section as a surety bond. Non refundable daw. 1st time I've heard of a bond that's non refundable.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
