Page 44 of 81 FirstFirst ... 3440414243444546474854 ... LastLast
Results 431 to 440 of 808
    Jun 2011
    #431
    Ground level horizontal tank, para maka-abot ang tubig kahit mahina ang nawasa.
    Pump at pressure tank na may top/bottom singawan at pang bleed.
    Jun 2011
    #432
    Left pipe galing sa tank+pump source.
    Right, top 2 pipes papuntang bahay.
    Right, bottom pipe galing nawasa source, may check valve.
    (Madalas kaya naman direct sa nawasa pressure, bihira lang mag on ng pump).
    On-off switch. Tapos may plug sa pump in case kailangan i-plug sa genset.
    Mar 2004
    #433
    PVC pipes? ... or PPR? ...
    Mar 2013
    #434
    we were advised years ago, that it is illegal to install pumps to higop directly from the nawasa pipe.
    i do not know if this is true or not, but boybi is right: hihigupin nang pump ang dumi nang nawasa pipes.
    This is correct. Booster pumps are not allowed in our village.. Kawawa the neighbors.
    Sent from my SM-G998B using Tsikot Forums mobile app
    Mar 2013
    #435
    Comprehensive setup there. Nice.
    #436
    Quote Originally Posted by bxr monkey View Post
    it's almost lego-easy now, what with those non-metallic pipes to work with.
    back in the day, we had to use lead-type metal pipes. hassle to cut and thread.
    but one advantage of these metal pipes, is that they're very, very sturdy.
    the plastic pipes can leak, when struck out of position... we had one such.
    Nov 2017
    #437
    Ok ang tank na nasa ground level, mas easier to maintain, and with PV/Solar panels getting more affordable, pwede yung pressure pump set up sa PV/Solar.
    Yung overhead tank ko, wala syang pressure pump and tank, enough na yung pressure for a good shower. Medyo warm pa yung water sa afternoon pag in use kasi exposed hehe.
    For emergency lang naman purpose. Since malakas pressure ng water provider, may float valve sa tank pero naglagay pa din ako ng gate valve papasok kasi one time nasira float valve, kailangan pa akyatin para palitan hehe. Then same may set up ng gate valve papasok sa house.
    Next house construction, good inputs to have a ground level tank reservoir and pressure pump.
    Jun 2011
    #438
    ^ salamat. Oo nga, next siguro ikabit pump sa solar para libre pressure boost.
    Ay PVC lang, since old setup na. Although bago iyong pump at pressure tank, nag re-align ulit kaunti ng pipes at valves.
    Salamat.
    Ah oo bawal talaga sa mga village at utilities ang direct pump sa main line:
    [main]=>[pump]=>[house]
    Madalas indirect allowed. Nag tanong muna kami sa village sa province bago nagpa install:
    [main]=>[tank]=>[pump]=>[house]
    Tapos naka parallel sa:
    [main] =>[house]
    May mga check valves para walang backflow from 1 source to the other.
    Ah oo doc, GI pipe mas mahirap mag lagare tapos kailangan ng threading tool. PVC madali lang nga. PPR naman kailangan ng heater/jointing/fusing tool. Hindi yata siya basta glue glue.
    Mar 2004
    #439
    PPR heaters are cheap these days ... PPRs are also more flexible and less likely to break when hit ...
    Jan 2016
    #440
    I bought one 4 years ago for 900 kesos
House Construction
