Results 141 to 150 of 808
June 4th, 2019 04:39 PM #141
I always try avoiding planting rails on floors. This is to future-proof things. Should floors need changing, no rail removal, tampering nor workaround needed.
If staircase & upper floors are of concrete, you can use chemical anchors(Hilti, Sika, Fischer) to plant metal angles or channels on the vertical sections(beam face or side of staircase) for your balusters to bolt on to. This method will have better pivot/movement resistance than floor-mounting.
Here's an example of rugged treated wood anchored on the vertical beam face, not thru the floor.
Tried looking for 1st hand stair application pics to share. It has been a while since we've done stair rails in wood. They were likely stored & lost in older phones.[emoji852]
June 4th, 2019 04:51 PM #142
June 4th, 2019 05:07 PM #143
You can always guinea a section or 2. Test for durability as they are safety rails. Should your plan fail, look into China SS stair rail components you can use w/ minimal or no weld assembly, sir. Aluminum sections can be mixed in, too. Hoboer than custom stainless.
June 4th, 2019 05:26 PM #144
June 4th, 2019 05:33 PM #145
June 4th, 2019 06:34 PM #147
- Nov 2017
- 1,748
June 4th, 2019 07:43 PM #148
June 4th, 2019 08:29 PM #149
Do I ask the installer to use a 1/2" diamond tip bit to make it through the tiles and then drive the threaded rods bro? Or drill down until the entire length of the buried portion of the rod and then screw it down?
I hope these threaded rods are available at the local Wilcon hehe.
- Nov 2017
- 1,748
June 4th, 2019 08:53 PM #150
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
