Results 91 to 100 of 808
January 4th, 2019 12:39 PM #93
January 4th, 2019 12:39 PM #94
It's a pain for everyone(the owner, the most) to deal w/ leaks....the damage, the inconvenience & the cost.
Though we've so far had luck w/ measures to not lean on surface applied waterproofing as primary leak defense(by concrete mixture & thickness tweaks), the designers we're blessed to work w/ have always been conscious in efforts to keep slabs away from element exposure.
January 4th, 2019 12:42 PM #95
I feel the same way about balconies sir, I compare it to a treadmill, you use it only for a month and then put it aside.
January 4th, 2019 12:49 PM #96
- Mar 2013
- 6,160
January 4th, 2019 12:53 PM #97Hehe true about balconies and how often they are used..... Especially in our climate. But yeah waterproofing will drive you nuts.
Congratz on your new home. Your starter home is the dream home for many already. Hehehe.
January 4th, 2019 12:58 PM #98
- Nov 2017
- 1,748
January 4th, 2019 02:09 PM #99Its always depend on the structure
itself weak structures of balcony slab are prone to cracks which causes leaks. Always provide temperature bars for exposed concrete slabs and concrete mix should have good workability.
- Jan 2019
- 19
January 5th, 2019 12:08 AM #100
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
