Page 1 of 2 12 LastLast
Results 1 to 10 of 808
    Oct 2015
    Guys, medyo off topic question ko, mas adviseable ba na tambakan ang bakanteng lupa at hayaan maging stable at masinsin sa ulan bago tayuan ng bahay, or no need na panambak at hayaan na lang builder company na magtambak kasi maghuhukay din naman sila sa mga pundasyon? Salamat ng marami sa sasagot...
    Quote Originally Posted by draiman View Post
    You won't want your foundation to sit on fill. Fill and compact in layers as you progress.
    Jan 2016
    Which would be cheaper, fill and compact or just build a slab over void treating it just like a 2nd floor slab?
    Nov 2017
    Fill mo nlng ng maganda quality panambak like yung lastilyas type para kasi adobe yun matigas unlike yung napupulot lang sa tabi tabi ng waste soil.
    Aug 2017
    For me let it done by your contractor. Hukayin ng malalim and have a mat foundation for stronger structure results.
    Sent from my iPhone X using Tapatalk
    Nov 2017
    Quote Originally Posted by montro View Post
    Mat foundation kung malaki budget mo.
    Aug 2017
    Quote Originally Posted by maxpedition View Post
    Yes budget permitted. That's my foundation sa aba kong bahay. As per my architect preparation daw sa the big one
    Sent from my iPhone Xs Max using Tapatalk
    Nov 2017
    Kung mababaw ground water level mo ok mat foundation pero kung malalim naman pwede ka naman mag isolated footing. Depende rin kung ilang floors at ano naka load kada floor
    Jan 2016
    The CE that designed my structurals also did prep for earthquake, but instead of mat, he did three layers of steel reinforcement for my 2 storey house, he had different number and sizes for levels 0 - 1.5m, 1.5m - 4.50m and 4.5m to 7.5m, I only realized this when I was gearing up for the construction, pretty heavy on budget, as it requires multiple splices. 20mm pa ang gamit sa 1st layer, and all are grade 60.
    Aug 2017
    It's really expensive bro. Mine was 25mm grade 70 with certificate for my mat foundation. Then on the second floor 20mm. Then 3rd to 4th till rooftop 15mm (usually Standard size). It's double purpose mini bldg for my bed spacer business
House Construction
