Results 41 to 50 of 808
Unregistered user
- Jun 2003
- 1,121
November 10th, 2005 10:29 PM #41if you are in bacoor i know the hardware that offers best prices is kelly
and in dasma its dasma citywide
-sa bakal naman silvercity offers good prices but sometimes may catch (undersize)
these are what ive heard from my customers who are contractors but usually you cant really rely on that alone best way is to go the big shops in your area and have them estimate your required materials
sometimes hindi kasi lagi same ang price depende rin sa quantity ng kukunin mo and depende na lang kung kakilala mo ang bibilhan mo
you are from meadow wood pala marami na akong nasupplyan dyan na mga houses pero indirectly usually mga contarctors bumibili sa akin e
hth
Unregistered user
- Jun 2003
- 1,121
November 10th, 2005 10:32 PM #42Originally Posted by fLaKeZ
tama golden hill nga ang mura sa bacoor area :D
flakez suki ka ata sa kingtop at yun ang ginawa mong landmark hehehe
- 106
November 11th, 2005 01:47 AM #43Parang close na ata yung King Top. How about roofing? Anybody had an experience sa cement tiles ng CPAC Moniers? Dinig ko ok daw. Any suggestions?
November 11th, 2005 02:04 AM #44
ano na ba average price per sqm sa pagpapatayo ng house sa manila..
calling tsikoteers sa construction firm
November 12th, 2005 12:13 AM #45
Originally Posted by Sheep
November 12th, 2005 12:17 AM #46
eto tinanong ko na erpat ko.
steel - goldenhill
cement - kilomter 17
hollow blocks - joan and hanna ata, basta something like that.
paint, woods - kelly
steelworks (gates, windows, fences, etc...) - flakez! nyahahaha. pm mo ko kung gusto mo pagawa. mura lang. haha.
tanong ko next time yang roofing.Last edited by flakez; November 12th, 2005 at 02:10 AM.
November 12th, 2005 12:19 AM #47
OT: sheep ano mga sinusupply mo? baka mura sa iyo. hehe.
ooopppsss.. sorry, na post mo na pala. hehehe
sige pag may kelangan kami contactin kita, baka mas mura sayo kumpara sa kinukuhanan namin.Last edited by flakez; November 12th, 2005 at 12:25 AM.
November 14th, 2018 11:56 AM #48
Question lang mga CE tsikoteers sirs...
A 2 storey house with firewall on 1 side hence the columns are eccentric, if the 2nd floor slab is 4.8M from the footing, do I need a strap/tie beam in addition to the ground floor beam/wall footing?
My architect says we don't need anymore so that I can save money he says, but I am not comfy.
The plan has a drawing of a tie beam but the structural analysis he says does not provide for one. The plan drawings were done by another architect and the struct analysis was done by a CE and also revised the steel requirement from 8pcs 16mm/column to 8pcs 20mm/column. Isn't this an overdesign? The steel diff alone is worth another 300k.
November 14th, 2018 01:54 PM #49
Structural design is relative to loads & stresses: axial, lateral, dead, eccentric, torsional, shear, moment & so on. Soil bearing capacity, distance between columns, their sizes & respective tributary loads must also be factored in.
That said, the best guy to ask this simple & specific concern would be the building's structural designer. He should be most familiar w/ his design criteria & assumptions.
Generally, shortening a column's unsupported length, provides more stability & adds to the area's safety factor.
- Nov 2017
- 1,748
November 14th, 2018 02:19 PM #50Exterior or interior wall more than 3 meters width should have column stiffener and for 4.8m height of wall you should provide beam stiffener same width as you chb. Regarding your tie beams reinforcement if the span of your beams is less than 5 meters you can use 16mm but greater than that use 20mm.
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
