Results 71 to 80 of 120
June 6th, 2013 11:56 AM #71
Ito phase converter sir boybi.. baka pwede reversible yan 3phase in and 1phase out.
Rotary Phase Converter Philippines - 12392041
June 6th, 2013 12:42 PM #72
Ginagamit mo na pala na parang single-phase e... Ganyan din ang ginagawa ng mga power distributors... Iba't iba ang phase na ginagamit ng mga bahay for a more balanced loading for power saving...
The maximum capacity of one phase (line to line) = 45/1.73 = 26KVA....
19.4K:tomato:Last edited by CVT; June 6th, 2013 at 12:47 PM.
June 6th, 2013 01:14 PM #73
So ok lang mawalan ng load yung isang phase then mabawasan pa yung isa pang phase. So di ko na pala need ipa-reconfigure itong wiring ng genset ko.
Signature
June 6th, 2013 03:48 PM #75
baka lang sir boybi na reversible input and output lang naman yan or they might have a 3phase to 1phase na phase converter. naki singit lang nug bata. give them a call na lang sir.
June 6th, 2013 07:12 PM #77
pwede nga sir boybi yan ung sinabi ko nung una na line 12 or 23 or 31 na makakakuha ka ng 230v dyan na 1phase. wag lang masyado malaki voltage unbalance kung hindi iinit transformer.
June 6th, 2013 07:38 PM #78
Tinakot kasi ako ng electrician, dapat daw balance sa lahat ng phases ang load.
Signature
June 6th, 2013 09:11 PM #79
worst thing that could happen if unbalance ang load is iinit ang transformer at rated load/capacity. pero mababa naman load mo sir boybi, it should be no problem.
June 6th, 2013 10:43 PM #80
Ilan aircon ba ang kaya ng 22kva? May 1hp pa na water pump and refrigerators. Plus mga ilaw.
Signature
Senators suggest window hours in odd-even system on Edsa rehab Senators urge window hours in...
SC (temporarily) stops NCAP
