Results 21 to 30 of 120
May 27th, 2013 10:00 PM #22
Sale ata sa ace hardware ngayon ng genset less 30%, nakita ko kanina lang sa festival mall. IMHO, 2kva is ok kahit naka 1hp AC plus ref and other stuff like ilaw and electric fan.
1400W (bitin ito para sa akin is around 13,999, 2kVA powermate brand is around 15,999.
3kVa for me is a bit large and 2kVa is very handy na din, so if you feel like lending it with your parents and in-laws better you can do so at the back of a small sub compact car like vios.
But if you have bigger car like Fort, Montero and the like transportation of 3kVa mabigat lang talga sya comparecd sa 2kVa.
HTH
May 27th, 2013 10:05 PM #23
Minimum 3kva believe me. Bitin na nga sa akin 3kva eh
Sent from my iPhone using Tapatalk 2
May 28th, 2013 10:36 AM #24
May 28th, 2013 10:55 AM #25
What additive do you pour in on seldom-used generators to prevent gasoline from going stale?
- Jun 2006
- 1,139
May 28th, 2013 11:17 AM #26Before i tried using the additive that you can buy at ace and handyman, only to find out that it was also expired. Now rhey erased the expiration dates and still sell the product.
I use blaze on my china genny and it does not go stale even a year of storage. Every year i clean,changeoil and drain my genset.
May 28th, 2013 02:25 PM #27
required na lagyan ng additives ang fuel? sa mga diesel gensets, i don't remember putting any additives.
May 29th, 2013 05:23 PM #29
All types of fuel go stale (yes, even diesel) with or with out additives. On seldom used gensets, the best way is to drain and or run the genset once in awhile. Or you can premix the old fuel with fresh fuel, but be ready to encounter misfires (palya) as the engine tries to burn the (mixed) contaminated fuel. As mentioned above, also try to use good fuel, and refrain using E10.
May 29th, 2013 05:57 PM #30
The CHAdeMO plug is definitely a concern. And yes, you are potentially purchasing old tech. In...
2021 Nissan Leaf
