Results 901 to 908 of 908
September 9th, 2024 08:23 PM #901
The diagram oj88 posted would be the usual setup for generator with solar system ... but have seen some solar inverters have input for generators ...
May 3rd, 2025 04:36 PM #903
Sa mga meron solar sa bahay, ano ba actual efficiency ng solar panel. 20% lang ba talaga?
- Feb 2014
- 2,711
May 5th, 2025 12:37 PM #905yung rating ng panel is from artificial "lab" conditions at 25 degrees c. which you'll never achieve in the real world
w/ my old polycrystalline panels i could get at most 75% of the rating on the sticker. monocrystalline should be slightly higher. then there are bifacial that are even higher still if you could somehow reflect light into the back of the panel
May 5th, 2025 05:01 PM #907
May 21st, 2025 10:39 AM #908
So bale x4 ng KW ng System ang ma harvest sa whole day?
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
