Results 711 to 720 of 908
March 1st, 2015 05:55 PM #711
^^ kapag ang supply ng AC current ay fluctuating (like meralco) kailangan ng UPS para laging constant ang current supply nito pero kung ang appliances naman ay auto volt from 110v to 220v no need na
March 4th, 2015 08:34 AM #712
March 4th, 2015 08:37 AM #713
March 4th, 2015 08:53 AM #714
Ang mahal din ng large capacity UPS bro, hehe. Kaya balak namin tutal daytime lang naman ang brownout according to Sec. Petilla, mag-mall na lang or hotel. To be fair di naman kasalanan ng current admin yung shortfall sa power. It takes a long time to put up power plants. Si GMA ang hindi naghanda ng future capacity. Ok din lang ako sa ILP, yung mga komunistang nagpipicket lagi sa Mendiola na lang ang magtiis sa init at dilim kung gusto nila.
- Jul 2013
- 2,450
March 4th, 2015 10:17 AM #715uls
post mo na available units mo.
a friend of mine is looking for one.
uls
March 4th, 2015 11:35 AM #716
March 4th, 2015 12:21 PM #717
salamat mga kapatid.
Got mine sa miguel motor electrical supply. 713 evangelista for commandant quiapo manila. 313 5899 381 82 44 5.5 kw gen set diesel. kala ko 6 kw. 35,000 last 7/28/14 2 years service warranty siya
March 11th, 2015 09:22 AM #718
Fired/Warmed up our genset last weekend...
Running A-OK.....
25.9K:branch:
March 11th, 2015 10:07 AM #719
DIESEL OR GASOLINE FED GENERATOR
1. Can you pls share your opinion here what would be the pros and cons for each, aside from cost difference and noise level. Noise level is not an issue for me, and cost is a matter of upfront CAPEX (in favor of gasoline) vs regular fuel OPEX (in favor of diesel).
2. Also, I can see some ads saying inverter type and non-inverter type generators - what does each mean?
3. I need to provide for all lights, 2 LED TVS, 1 ref, 1 desktop PC and 2 electric fans. Is 6kw or 6 kVA more than enough?
4. What is the difference between kW rating and kVA rating?
5. What is the significance of single phase vs triple phase? What is suitable for home use?
6. And what is the significance of power factor, is it relevant for home use?
7. Can you recommend a good shop or seller for generator for home use?
Thanks for those who can help me understand.Last edited by ano727; March 11th, 2015 at 10:09 AM.
- Jul 2013
- 2,450
March 29th, 2015 07:44 PM #720Not to be rude, but you are asking a lot in one post. I suggest you google first, and ask here what you do not understand fro your own research.
I am willing to answer some of your questions based on my own googling but first, how much is your budget?
If I am correct, diesel gensets are more expensive than gasoline gensets. You can find diesel genset only from units with output of 3000watts up. Lower output gensets are gasoline fed.
Inverter- more expensive but also more efficient than common gensets.
6kva genset is more than enough for the specified appliances.
kw vs kva? Yan ang ndi ko alam. Hahaha
Sent from my GT-N5100 using Tapatalk 2
and its right above an electric motor....
BYD Philippines
