Results 351 to 360 of 908
July 18th, 2014 06:32 PM #352
July 18th, 2014 07:04 PM #356
July 18th, 2014 07:10 PM #357
sir sorry di po
may power factor po yun
How to Convert Watts to VA and kVA to kW Simplified -- Converting Volt-amps to Watts the easy way, VA to Watts, Amps to A, watts to kVA
Converting Watts to KVA (watts to kilovolt-amps)
The conversion of W to KVA is governed by the equation KVA=W/(1000*PF)
For example 1500W/(1000*0.83) = 1.8 kVA (assuming a power factor of 0.83)
or try this:
http://www.dieselserviceandsupply.co...alculator.aspxLast edited by uls; July 18th, 2014 at 07:13 PM.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
