Results 1 to 20 of 60
    Sep 2006
    Are Filipinos prepared for the Big One?
    By Tony Bergonia
    Philippine Daily Inquirer
    First Posted 02:29:00 03/14/2011
    MANILA, Philippines—About 34,000 people dead instantly and 24,000 dead or dying in the rubble. About 110,000 injured and needing immediate treatment. Five hundred fires raging simultaneously.
    Metro Manila faces these and several other horrific scenes should a 7.2-magnitude earthquake hit the country’s most populous urban area, according to a report released by a multinational firm doing intelligence work for clients on business and security in the Philippines.
    Pacific Strategies and Assessments (PSA) said in its report on Metro Manila’s quake vulnerability that while quakes were normal occurrences in the metropolis, the effects of a 7.2-magnitude tremor were likely to be made more terrifying by a lack of preparedness and failure to enforce zoning laws and building standards.
    The report, “Metro Manila Earthquake Vulnerability Assessment,” was released in August 2010 shortly after a massive earthquake killed thousands in Haiti.
    Pete Troilo, executive director of PSA, said that while the report had not been updated in the wake of the 8.9-magnitude quake that devastated northeastern Japan, “it still holds.”
    “It just gained added relevance,” Troilo said.
    The report pieced together data from a study prepared by the Japan International Cooperation Agency (JICA) and the Metropolitan Manila Development Authority (MMDA), and results of PSA’s own study on the impact of a massive earthquake on businesses and industries in Metro Manila.
    Apocalyptic scenarios
    Should a 7.2-magnitude quake slam Metro Manila, the PSA report listed these apocalyptic scenarios aside from the unimaginable number of fatalities that such a tremor would bring:
    • At least 117,000 homes would either collapse or suffer heavy damage, rendering 1.2 million people homeless.
    • A fourth of public facilities—hospitals, schools, fire houses and police stations —would suffer damage.
    • Damage to water reservoirs and purification plants would immediately cut 4,000 water supply points.
    • At least 30 kilometers of electric cables cut, removing the supply of power instantly across the metropolis.
    • At least 100 km of telecommunications cables cut, suspending services “for several weeks if not longer.”
    • Closure of airports, damage to major ports and cargo handling infrastructure.
    • Closure of roads and damage to nine bridges and a government not functioning because of damage to its offices and facilities.
    “While earthquakes are a global and natural phenomena that can hit any city without warning, there are both openly declared and unspoken reasons why Metro Manila … is particularly vulnerable,” the PSA report said.
    Poor building standards
    “Despite international assistance programs that have gained considerable momentum over the course of the last several years, unreliable infrastructure system, poor building standards due to corruption in the construction and inspection process, informal settlements … in hazardous areas and a lack of government resources and coordination … are just some of the factors that plague the country’s disaster preparedness,” the PSA report said.
    It said that should a 7.2-magnitude quake hit Metro Manila, the post-quake scenario “would more closely resemble Port au-Prince (capital of Haiti).”
    “If this is true, one need only remember that six months after the Haitian earthquake, rubble and collapsed buildings still dominate the city landscape and most roads are still impassable,” the report said.
    Based on PSA’s own findings, a staggering level of death and destruction was not remote in Metro Manila following a massive quake because of utter disregard for rules on building and construction.
    The report doubted whether builders had taken into consideration that Metro Manila’s soil was mostly made of “quaternary alluvium [alluvial deposits of sand, gravel, silt and clay], which is generally not suitable for construction of big infrastructure and buildings.”
    Despite rapid urbanization and the decay that it brings, “the national government has failed to adopt a comprehensive land use plan for Metro Manila,” the report said.
    Weak enforcement
    “The lack of coordination and checks and balance mechanisms between local and national agencies have likewise weakened the enforcement of building standards with many residential and commercial buildings built on hazard-prone areas, using substandard construction materials,” it said.
    Quoting the JICA-MMDA 2004 report, which was kept from the public until 2008, the PSA report said that in case of a 7.2-magnitude quake, Metro Manila “could be separated into four regions … due to the collapse of buildings, destruction of elevated highways and bridges, impassable roads and fire.”
    “The Pasig River exacerbates the potential of … separation in the event of an earthquake,” it said. “For example, earthquake analysts contend that if the Guadalupe Bridge across the Pasig River and along EDSA collapses or suffers significant structural damage, the Ortigas Center area would be virtually shut off from the areas south, including Makati City,” it said.
    The report said casualties were likely to be caused “first and most directly by building collapse and spreading fires.”
    “Inadequate fire-fighting capabilities and the probable loss of water in many areas of the city would diminish many of the efforts to combat shanty town fires,” it said.
    Even without a massive earthquake, the report said “approximately 70 percent of fire hydrants in Metro Manila reportedly have no water.”
    Lack of open spaces
    Operations to evacuate thousands would be hampered by the sheer lack of open spaces in the metropolis, according to the report, because open spaces like parks, schools, sports arenas and burial grounds “now comprise less than 1 percent of total land areas of cities in Metro Manila.”
    “With a daytime population of more than 14 million, existing rescue and relief facilities of local governments across Metro Manila will simply be overwhelmed,” the report said.
    “Lack of hospitals, fire trucks and logistics are likely to hinder rescue and relief operations. The number of medical personnel, hospital facilities and ambulances … is likewise insufficient to treat thousands of earthquake victims,” it said.
    Nakakatakot pag nangyari ito, lahat ng pagkain at tubig naka stock sa bahay di natin magagamit pag nakaligtas tayo sa nagiba nating bahay...
    Filipinos are not prepared to a major earthquake.
    If a major quake happens, what happened in Haiti is a more likely scenario than anything else.
    If the study were to lump those illegal squatter colonies where there are no enforcement of the building codes and the state of Haiti, pwede pa icompare...
    di kasi uso sa atin ang overengineering
    puro lang improvised engineering and underengineering(particularly camelia)
    puro pa substandard tapos ang mahal pa ng cemento
    yung tipong pwede na yan
    Sep 2009
    Wala akong tiwala sa mga smaller buildings. Malls lang at mga high end na gusali ang pinagkakatiwalaan ko.
    Quote Originally Posted by eld View Post
    malls? not really. remember MOA?
    we have a relative, an architect who worked w/ the construction of Mall of Asia before. during that time, he says a part of the mall was sinking, kaya na-delay daw yung opening nung 2006. remember, the delays that went for months?
    perhaps this was corrected na. ang mahirap, baka minadali lang para matuloy yung opening noon.
    Aug 2003
    Quote Originally Posted by safeorigin View Post
    that sums up how most pinoys think. putting too much stock in abilidad at remedyo. puro "pwede na yan".
    prepared? ano prepared prepared?
    bahala na
    May 2010
    ^YES. It will be very disastrous.
    Luckily for Japan, their people are disciplined. When the relief goods were being distributed, they lined up properly and waited patiently. While most of us Pinoys can't even line up properly and will only complain that it is taking them so long to wait.
    Handa naman ang aking Canadian passport hehehe...
    That's the reason we naturalized for one back in the early 90's. We know PHL is so unstable socially and politically pag may major disaster siguradong pandemonium...
    Recently the site admin suggested to buy hard hats for the employees. I jokingly told her that the buildings here in BGC are built to withstand 7 magnitude earthquakes. If it goes beyond that and we happened to be inside the building, no hard hats can save our a$$es. [emoji28]
    I don't get it, is the building a construction site? Or are they suggesting have hard hats ready to wear in case of an earthquake? Or are they suggesting employees always wear them?
    They are to be worn after an earthquake, when you evacuate the building.
    Oct 2023
    obviously not ready. Kita nyo mga building tabi-tabi walang allowance.
    sinabi na ni architect falafox na ideally malawak dapat pagitan. Eh ako hinid nag-aral ng architecture eh basic observatory ko lang na hindi dapat tabi-tabi highrise.
    Pag nass binondo area nga ako kinakabahan ako pag tumitingala kasi ang tataas ng building tapos ang kipot ng kalsada
    example paano kung lumindol at bumagsak building eh for sure mahina 5years bago bumalik ang negosyo kasi damay-damay yan domino nya area ng babagsakan.
    Pero kung yung highrise may malaki space sa paligiid kahit bumagsak less collateral damage.
Are Filipinos prepared for the Big One(earthquake)?
