Results 1 to 20 of 20
    I know a lot of our members here have a lot of know how when it comes to home repairs
    I am planning on having my cabinets repainted DIY only. I don't want to ask our contractor anymore because he is kinda expensive and normally something else would come up so it always exceeds the budget.
    How do you repaint cabinets so that it has a glossy white finish?
    Use glossy white paint
    Surface must be well sanded, wood grains must be evened out with filler. Then spray base coat 2x followed by sanding. Pag di pa din pantay spray base coat ulit, sanding ulit. Then 2-3 coats of top coat. Just like in painting cars di ka dapat nagmamadali. All paint coats must be completely dry before you do sanding or apply the next coat. Practice ka muna sa back side ng cabinet door or any scrap wood around. Eto yung mahirap, yung practice. Kaya mahal ang charge ng mga pro kasi alam nila you are more likey to mess it up if you do it yourself. Then they charge you higher when you call them to fix your mess!
    If you use a brush ot roller then don't expect to get professional looking results. May nabibili naman na airless paint sprayer, magastos lang nga sa thinner. Meron din sprayer na may sariling air pump, no need for bulky air tanks. Look in olx or ebayph for these.
    Mabusisi pala. Akala ko ipapatong lang yung paint Top coat is the glossy white paint ba?
    Oct 2009
    kung gusto nyo po mam bili nalang po kayo ng wall stickers sandali lang po yan magagawa kaagad..
    sa cabinet po kasi ,masilyahan din po yan.tapos sanding.after spray ulit ng primer.after sanding po ulit.tapos body color.spary ng 3 times.wet sanding po ulit saka finishing spary ng 2 times .top coat.
    kapos po ang maghapon depende sa size ng cabinet nyo...
    Quote Originally Posted by jaypee10 View Post
    ano yung wall sticker? instead of paint ididikit na lang?
    yup, like wall paper.
    Ducco tawag nila diba?
    Feb 2009
    Duco from DuPont paint-acrylic based
    Feb 2009
    Self adhesive shelf liners
    Feb 2009
    Ever thought of using leatherette and rubber contact cement as adhesive? That is if it is not kitchen cabinet exposed to heat
    Sep 2008
    Sep 2008
    Kala ko din noong una madali lang yang mag spray paint kung todo bili pa ko ng compressor at kung ano ano pang spray gun..nag practice ako sa room ko since bagong gawa palang.. ang ganda ng kinalabasan hahaha parang yung mga underpass na pinag tatambayan gangster.. in the end kumuha nalang ako ng Prof Painter.. medyo mahal yung labor ng Kitchen Cabinet ko 18K..automotive paint finish daw yon mas mura kung ducco 10K lang daw..
    ngayon nag pipintura na sila sa cabinet ng room ko at bed with one side table 14k naman ang labor. pero sulit naman maganda kinalabasan mas makaka tipid pa kesa bumili ka ng furniture na gawa na.
    Quote Originally Posted by NightRock View Post
    wow ang mahal! Yung labor ng pinta kada araw o per item talaga?
    Ever since our suking pintor left for abroad we could not find anyone that would match his skills so we don't get to maintain the paint at home anymore. It's really sad na yung mga magagaling umaalis ng bansa.
    Cathy, they would not be leaving to work overseas if they can find work at home that pays enough for them to pull their families out of poverty. We all have the right to pursue our dreams di ba. If you want to keep them ypu'll just have to pay them.
    Yeah. I can't blame him for leaving since it really pays so much better abroad. My Dad said he left for Saudi Arabia. Pulido talaga siya gumawa at masinop. Mga nakukuha namin never na umuulit kasi hindi kami satisified. Painting is not that easy pala
    Quote Originally Posted by robgowild View Post
    Maganda nga yung wall sticker na dinidikit lang sa mga cabinet. Para syang wall paper pero it looks like the cabinet is painted kapag nailagay na
    sa True Value or Ace ba meron niyan? Wala ata ako nakikita? Hindi ba mas mahirap mag gupit gupit with all the grooves of the cabinet?
    kahit ako nagulat sa presyo ng labor 18k sa kitchen cabinet lang yon kontrata na.. then 10K sa kama ko lang at cabinet ng damit at isang side table.. pero ok naman silang gumawa base sa picture na pinadala sakin hehehe
    Oct 2014
DIY Cabinet Repainting
