Results 1 to 10 of 23
- Jan 1970
- 396
June 11th, 2006 01:26 AM #1anyone into cycling? thinking of getting into it as a form of exercise and recreation only, nothing serious.
im a big guy, around 210lbs. what's a good starter bike for me? where to buy? how much? leaning ako towards mounting bikes, rather than racing bikes.
June 11th, 2006 01:34 AM #2
there was a long thread about cycling here somewhere...
you can choose from lots of bikes sa cartimar or quiapo(quezon blvd, opposite side of the church). price range is P10K to P100K+..depends really on what your budget is.
- Jan 1970
- 396
June 11th, 2006 01:57 AM #3meron na plang thread.. thanks boy t!
http://tsikot.yehey.com/forums/showt...hlight=cycling
- Jan 1970
- 396
June 11th, 2006 02:30 AM #4is this a good buy? 13k daw asking..
http://www.bidshot.com/index.php?pag...d=275599&view=
specs: body frame: alloy wd serial no. at the botom,maganda yung pgka2welding kng san dapat matibay ang joints. brand: KORE botom bracket: shimano sealed bearing chain:shimano plato: 3 speed Small size,shimano malaysia pedals: M.O.B. alloy blak kambyo sa likod: shimano tourney changer sa plato:standard issue alloy seatpost:gts blak sadle: velo plush blak v-brakes: shimano altus blak rims: blu orgnl deemax(tinangal ko lng yung sticker,masyado kasing colorful) spokes: standard issue alloy hubs:specialized,front n bak tires: maxis mofo xc size of tires:yung ngka2bit sa handle bar: voxon alloy blak handle bar: forgot the brand,but its alredy anodized,scratch proof,blak grips:amoeba cable casing: MOB snake skin like design cable wire:shimano japan cable stoper:MOB fork:Spinner grind1,inch travel speedometer:CI deck shimano wd sprocket reading(ryt side),plato reading(left side),speedometer(midle) headlyt:cateye,yelo lyt, med bat. yung mga bulitas: sa gulong sa harap pti sa likod,japan made Selin it 4 13k neg. has scratches but basing on its function,A1CONDITION.
June 11th, 2006 10:36 AM #5
The bike is a good deal from what I read and from the pictures.
I would only change one thing (if and when you get this bike). Change the seat to a wider one (women's seat models). A standard seat can be painful if you are a big guy. Women's style seats are wider, with better padding and will give better support & comfort for bigger guys too.
- Sep 2005
- 188
June 11th, 2006 12:51 PM #6Originally Posted by slip-slick
Its a good buy considering puro japan na yung parts. And another good thing on buying bikes with japan parts is kahit i-stock mo sya at paalikabukan for many years, pagpunas mo, parang bago pa rin
- Sep 2005
- 188
June 11th, 2006 12:53 PM #7Add ko nga pala consider having front and rear shocks sa mountain bike, ang sarap sa off road
June 11th, 2006 10:05 PM #8
mukhang ok na rin for a starter bike, not very sure kung good buy nga talaga since pre-owned na sya and walang nalagay kung gaano ka-old, sumemplang na ba bike na yan, or gusto lang mag-upgrade or nagsawa na. shimano parts are divided into yet several categories - from low end(acera) to high end(dura-ace yata). so i'm not sure what parts ang kinabit.
two years ago, bumuo ako ng bike. alloy frame din and mostly high-end shimano parts ginamit ko. umabot ako ng P15K. that's brand new.
so i suggest, check out muna sa cartimar/quiapo and see how much you'll end up with sa mga components mo. uso na rin kasi ngayon ang disk brakes, at i think medyo nagmura na. sa disk brakes, kelangan mo disk-brake ready ang frame, ang hubs, etc. usually set na yan. after ka makapag-canvass ng prices and it's not that far away from the one sa bidshot, e di magbuo ka na lang(usually bike shops nagbubuo, ituturo mo lang gusto mong piyesa).
save some money for a helmet, cycling shorts(with foam sa groin area) & a dri-fit shirt.Last edited by Boy Torotot; June 11th, 2006 at 11:27 PM.
June 11th, 2006 10:08 PM #9
Originally Posted by smalltimer
Tsikot Member Rank 4
- 1,842
June 14th, 2006 01:30 PM #10Originally Posted by ghosthunter
Check out the pros.
What you wanna buy for a saddle is something that takes care of your prostate or the Family jewel, lots of saddles out there that is designed for your pair of danglers
As for your post you can get more out of your 13k (If we talk about 2nd hand)
Try goin to this forum
http://pinoymtbiker.proboards7.com/
Just a reminder cycling is an EGO sport hehehehehe
Pero it builds character.
Ask blackMagic hehehehehe
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
