Results 1 to 19 of 19
    Oct 2003
    I saw this air cooler sa shopwise libis and it caught my attention. para syang aircon na nakatayo...it emits cool air daw and it costs Php 4T plus...50 watts and consumption (lesser consumption that other 16" electric fans)
    anyone who has tried this? worth ba?
    Oct 2003
    up ko lang
    Jun 2004
    nde din kaya ang sobrang init d2 sa pinas, ska pag gising mo sa umaga malagkit ang katawan mo dahil sa natuyong moist na lumalabas sa cooler na yan. hth
  4. FrankDrebin Guest
    Up ko rin ito. Interesting price for a cooler.
    thats the aircooler that uses water evaporation to cool the air, right? I think it can cool the air by 5 to 10 degrees (against ambeint temperature) only.
    Eto ata yung cooler na may water container sa likod. Pag nilagyan ng yelo, mas malamig yung hangin.
    Gusto ko ring bumili sana, kasi instead of using the aircon mas tipid ito.Pero sabi nung mga nakasubok na, sinisipon daw yung mga gumagamit, kasi yung hangin may kasamang parang "mist" para lumamig yung buong kwarto, totoo ba ito?
    Hindi siya ganun ka-effective. May mga clinics samin na gumagamit ng ganun. And medyo mahal na considering the smallest window a/c's start at Php 7k.
    Hindi din ganun kalakas ang cooling effect.
    Mas ok pa ang conventional electric fan since it can move large volumes of air and can help in evaporating sweat from your skin.
    Jan 2003
    ....meron pa palang ganyan. we had one many many years ago. yelo nilalagay ko nun.
    alam ko din napakatagal na niyan. ung mga lola ko dati meron niyan, ung nilalagyan nga ng yelo.
    tapos ung tropa ko meron pa rin hanggang ngayon, nung ginamit namin habang nanonood ng tv halos walang effect. siguro pag malamig panahon ok.
    Aug 2004
    we had that before at halos walang effect yan... and you need a ton of ice to cool the whole room.. mas magastos pa dahil sa kabibili mo ng yelo...
    IMO, not recommended...
    Sep 2005
    I would not suggest that as the so-called "air-coolers" actually use water to cool the air and at the same time, increases the humidity. In any given day here in the Philippines, especially during the summer, if you increase the humidity, you also increase the level of discomfort. Note that at 35 degrees C with low humidity would still be comfortable as compared with 28 degrees C with high humidity. My two cents...
    Jan 2003
    Quote Originally Posted by russpogi
    ...exactly, nung buhay pa yung ganun namen we eventually stopped putting ice or water. nakakapanglagkit ng katawan ang epek. mas malakas pa bumuga ang bentilador.
    Di po pwepwede satin esp indoors.
    Pag outdoors pwede, you see a lot of those sa Glorietta, Tiendesita, Market Market areas.
    Sya yung tipong big fans na nagmimist ng water from time to time. Works REALLY well sa outdoors.
    Madami nading golf carts na may ganun.
    May 2005
    Quote Originally Posted by theveed
    san kaya nakakabili ng supplies nito mga water mist system? gusto ko mag DIY para sa labas ng bahay in prep for summer.
    Oct 2003
    salamat sa mga info
    maganda yung effect nyan sa outdoors.. got a chance to see this sa Fernwood Gardens. puro mist over the plants and trees. hanep... ang ganda tingnan.
    masama yan for indoors especially kung marami kang electric appliances, nagiging moist yung air which is bad for electronics.
    Signature
    Mar 2003
    Quote Originally Posted by TFX
    sir usually sa mga plants store meron nyan...if you're in QC, sa circle meron nyan...cost about P6k + yata if im not mistaken...yung plant section sa tiendesitas ren is selling those.
    May 2005
    Quote Originally Posted by BeetOls
    tnx for the info. Try ko siguro yun sa tiendesitas, so under pala sya ng mga pang garden equipments. Yun sa circle ba tiangge style din yun tindahan dun?
Air cooler
