Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Jun 2013
    Good day. I got this whining noise when i turn my steering wheel and revving the car. Can anyone give some ideas on how to fix this? Thank you.
    Jul 2006
    Is your power steering hose still original? Or was it replaced na?
    Jun 2013
    Di original yung pressure hose. May tagas yung dati.
    Jun 2012
    ganun din ngyari sakin sir nong pumutok ung steering wheel hose ng crv ko.kaya in few weeks palit agad ng surplus.kasi mahal orignal.
    Jun 2013
    Quote Originally Posted by MonteroGLSV View Post
    Nawala po b whining noise? Nung surplus nilagay nyo?
    Jul 2006
    Your current hose maybe undersized (internal circumference). The system is developing high pressure due to that restriction, hence the whining sound.
    Jan 2009
    Check the obvious things also:
    1. Are you using a Power Steering Fluid (PSF) and is it of the correct type?
    2. Is the PSF level correct?
    Jul 2006
    Another thing, replacement hoses have this terrible tendency to collapse internally. On the outside it looks okay, pero inside barado na pala, creating more restriction.
    Jun 2012
    oo sir nawala cya,
    Quote Originally Posted by E240 View Post
    Hydraulic fluid level is low. Refill it and check for leaks. Loss of fluid shouldn't normally happen unless there is a crack or leak in the power steering system.
Power steering whining noise
