Results 1 to 6 of 6
- Jan 2010
- 23
January 16th, 2010 04:36 PM #1Hi, I need help. I have loaded my benz 230e with v-power with e10. Then after three days, I noticed palyado ang makina nya. Hesitant sya mag accelerate. I have checked timing, high tension wire and spark plugs, all fine.
Any inputs? Thanks
January 17th, 2010 12:16 AM #2
January 20th, 2010 11:37 AM #3
Hi, I'm not trying to scare you or anything... but it would be of the best interest if you drain your tank completely free of E10 and replace it with premium grade fuel.. What is your car? W123? W124?
Rumor is, on older 230E's.. the fuel system is not compatible with E10 blended fuels.... But on the later models "DAW" pwede... Since I have no proof or evidence to show you.. I'd suggest you load up on premium fuel next time just to be safe..
What I have though is proof that E10 "can and will destroy" your fuel system in one go.. if you use it further.. As what happened to a friend of our's and his W123-230E.. which was accidentally loaded with E10.. with the fuel system completely damaged... and super expensive (hard to find too) replacement parts.. He was forced to convert to a Stromberg carb..
Just my idea.
- Jan 2010
- 23
January 20th, 2010 11:16 PM #4*benzmizer *lowslowmerc
Thank you for the info.
I have loaded my 230e with xcs after that accident. And had a full tank and then some more xcs after (since tumakaw sya bigla sa gas) and now I was advised to have the engine overhauled (Story here)
Just curious though, how good is the idea of converting instead to stromberg carb? Where can we have it converted?
TIA
- Dec 2008
- 421
January 21st, 2010 12:01 AM #5must have damaged the rubber seals and piston rings... from the looks of it
- Jan 2010
- 23
February 5th, 2010 08:00 PM #6Hopefully wag naman.. so far it has been a few weeks na since that "stalling,misfiring,choking" problem and okay naman na yung takbo. Been loading unleaded/premium na nga din indiscriminately with or without e10 and i could sense no noticeable change/effect sa engine performance (or it's just me).
Xiaomi E-Car
