Results 1 to 5 of 5
    Apr 2009
    Hi all!
    Anyone know what ATF and DIFFERENTIAL Oil the Owners Manual recommends for a late 1970`s Automatic 280 SLC? Also how many liters needed of each for a fluid change? Thanks!
    patrick
    For ATF I use Mobil or OEM MB ATF, for the Differential Oil I use Shell Spirax SAE 90.
    Apr 2009
    Hi RONW!
    Actually i checked with CATS and VELODOUR and they both dont have the factory reccomended DIFFERENTIAL oil on stock.
    Based on your username, i assume you dont have the SLC. So are you implying that the DIFFERENTIAL oil on your car is the same one for the 280 SLC? I realize SAE 90 is standard for lots of car makes, but just wanted to be absolutely sure what would be good for our slc.
    What MOBIL ATF do you use by the way, or is there only one kind for mercedes benzes?
    How many liters of each do i need for a lube change? THANKS!
    I use the Shell Spirax diff oil on all my 4 Benzes (123, 124, 126, 140) and I checked the manuals of all 4 cars and they all have the same recommendation of SAE 90. On the ATF, I use Mobil 1220.
    Jul 2006
    Should be similar in specification, language can be translated quickly:
ATF and DIFFERENTIAL Oil for 280 SLC
