Results 11 to 20 of 164
- Aug 2007
- 171
April 5th, 2008 10:26 PM #11
April 7th, 2008 12:43 PM #12
For those who have GD Jazzes and Cities and curious about upgrading wheels, I'm uploading a few more photos.
The perennial bugbear of wheel and tire upgrade for GDs is rear fender rubbing under load. GD bodies require rear wheels that can successfully tuck into the fenders for problem-free results, which is why the proper offset and wheel width is critical.
My wheels have +45 offset and are a 7.0 width, which seems like the ideal combination for 16s and 17s. I gave the rear suspension a little compression by parking the car on a downward incline ramp. In this state the wheel and tire are still clear of the fenders---even after sitting my 170lb frame in the back seat.
Check the attached photos.
May 4th, 2008 04:27 AM #13
looks like that rear fender rubbing issue is also my friend's problem, he has some Wedsports installed on his GD, yep it's rubbing like whoa
May 4th, 2008 02:06 PM #14
I've got rubbing issues too... got wheels with a wide offset and I have taller than stock tires on my Lynx. It's a common problem on japanese cars, but just way more noticeable on the Jazz because of the low ride height.
So kasya ang 205/45R16 without rubbing? That's good to know... Am still looking at a Jazz as a second car. Just don't know what my financial situation will be by the end of the year.
May 7th, 2008 10:22 PM #15
Simple and clean. :-) I love your wheels..thought of purchasing those..but so scared of the rubbing issue.. hehe
May 7th, 2008 10:42 PM #16
Dang that baby is sooooo cool :thumbup:
You must love every driving minute in it
May 7th, 2008 11:11 PM #17
Hmmmm, fresh replies :D
FerioEG9Boi:
Stik/Pow is that you? Hehehe
Yeah, I have a friend on Jazz-City United who has these sick WedsSport SA-90s on his Jazz. Unfortunately they do rub on the rear fenders.
Niky:
Yep, 205/45R16s fit well given their mounting on an "appropriate" wheel --- 16/17x7.0 +42 offset and above should do the trick. I had my mom and dad as backseat passengers and I had none of the dreaded rubbing. No need for a spacer to clear the "flange" on the front brake calipers, either. ;)
Bougartt:
Yep, I really like the wheels, despite their disadvantages. Size is the most obvious, but the weight is more of a concern for me. The new rolling stock is 6 lbs heavier per corner compared to my stock 14" spare, so my fuel economy took a small but noticeable hit.
The price of looking good, I guess...but at least you don't have to worry about fitment, because they're just perfect for GDs like ours. The Circuit 10s even look good as 15" wheels.
Memphis:
Yes I do, thanks :D There's a lot more I want to do with the car in terms of parts, I just don't have the money.
May 7th, 2008 11:32 PM #18
Recent "mods" on the hamster:
- Work RS 21mm aluminum lugnuts. Anodized red, with keyed wheel locks.
- Custom-fabricated aluminum hub-centric rings, done by Autoplus. Inner diameter is 55.6mm, while outer diameter is 67.1mm. The rings are 8mm thick.Last edited by Type 100; May 7th, 2008 at 11:35 PM.
June 12th, 2008 09:54 PM #19
Akala ko bawal ang direct IMG tagging...hindi pala...
Anyway here are a few photos I took of my ride, with my new DIY-installed LED taillamps. No Photoshop alterations here, just a tripod and an 8-second shutter on my humble Sony CD Mavica.
A few photos of the install can be found here.Last edited by Type 100; June 12th, 2008 at 09:57 PM.
June 12th, 2008 11:56 PM #20
wow! DIY ng tail lights!
read the blog... buti na lang hindi nayari yung pagkabit... baka maaddict ka na sa DIY after niyan. :bwahaha:
ganda ng tail lights sir!
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
