Results 1 to 10 of 10
- Jul 2015
- 9
September 18th, 2015 06:07 PM #1Sir ung 98 mazda 323 ko po na matic ndi humahatak agad pag inaandar. Kelangan pa tapakan ung silinyador ng ilang beses bago sya tatakbo. Pero pag naandar na sya, wala naman problema sa pag change gear. Nangyayari lang talaga sya pag bagong start. Transmission problem po ba to? Much appreciated po ung mga sagot. Salamat
- Jul 2015
- 9
- Oct 2006
- 5,692
September 18th, 2015 07:47 PM #4
- Oct 2015
- 8
October 25th, 2015 01:33 AM #6
October 26th, 2015 01:10 PM #7
We have same problem TS. Change ATF lang yan. Umayos na ulit sa akin after ko magpalit.
October 26th, 2015 01:25 PM #8
He was just asking if the ATF change solved it. I don't think he implied anything about an ATF change being insufficient.
In my case, that's what I did with my Mazda too when the AT warning light turned on. ATF change removed the light, but a week after, the transmission would no longer be able to select the right gear upon startup. It was most likely a broken shift solenoid, but we ended up changing transmission because it's harder to find specific parts compared to just swapping to a new transmission altogether.
- May 2017
- 1
May 4th, 2017 11:42 PM #9good day. bago lang ako member and I have almost the same problem with my Mazda Astina. Problem is it wont change gear after going into 2nd. Tried changing Atf pro wla pa ring nabago.. can u help me. thanks
Sent from my iPhone using Tapatalk[/QUOTE]
May 5th, 2017 12:07 AM #10
did you use the correct atf?
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
