Results 1 to 5 of 5
- Aug 2009
- 5
October 21st, 2011 11:31 PM #1Good day everyone! I just want to ask if anybody experienced this, while the engine is running/idle then you opened the oil cap ay may tumatalsik na langis? My fuel consumption is good and no black smoke or what so ever from the exhaust. Is it normal or do you guys also experienced this? Thank you.
- Mar 2005
- 703
October 21st, 2011 11:37 PM #2why in the world did you do that? nevermind if may tatalksik na langis or not.
- Aug 2009
- 5
October 22nd, 2011 11:39 AM #3I did it because some said that you can see if the compression state of your engine is ok or not. Anyway, thank you for your reply.
October 22nd, 2011 04:01 PM #4
Well, you open the oil cap... guess what? There's a pair of camshafts and rocker arms in there moving at 800 revolutions per minute... that's over ten pumping motions per second... that are continuously being sprayed with oil. Having a little bit spit out of the oil cap when you take it off is normal. Having a lot maybe, maybe not, it actually depends on the specific design of the engine.
The real test is whether there's a great build-up of pressure if you put your had over the hole where the oil cap goes. If there's a lot of pressure, either you have a compression issue or a positive crankcase ventilation valve issue... but oil spitting by itself does not really mean anything.
- Aug 2009
- 5
You can try any of the Indonesian brands (GT, Achilles, Accelera, Neuton). For that size, you can...
Low budget yet good quality tires
