Results 1 to 7 of 7
    Jan 2010
    friends ask ko lang kung gumagana yung gas saver sa mazda 3? kung gumamagana what gas saver ang gainagamit mo? and may i know the FC. kase now 6-7km/l lang ako. im using the 2009 mazda 3 model. at if not gas saver nag work ba yung mga gas saver with the used of some microchip something? i really need to find a solution to save gas since oil price increases every week. thanks tsikoters.
    Gas savers will not work with the Mazda3 because gas savers do not work. Period.
    yes, it works...
    in your dreams...
    Feb 2009
    yes, it works...
    in your dreams...
    yes it does, when you adjust your tire pressures to specification, change your air filter, check your brakes for dragging, check your thermostat for correct operation, reduce the weight of the car by removing unnecessary weight, be light on the gas pedal, change the paint color to lighter one, tint the windows, perform tune up and plan your trips. i used to work for a scam company way back in the '70's. how it made people think the gadget worked, we did minor tune up and check and adjusted tire pressures. sure, it worked. it made the company owner richer
    Yeah it does. Lagay mo sa BMX.
    May 2010
    It does. Really does. it really really does NOT work.
    Mar 2005
    You need to invest in some aftermarket parts to get your FC up. Cold Air Intake, Aftermarket headers, a ecu piggyback tunning, some lightweight compromises, and driving habit changes as well.
do gas savers work with mazda 3?
