Results 111 to 120 of 272
March 5th, 2018 10:58 PM #111
March 5th, 2018 11:25 PM #112
They said that they are using synthetic oil and is good for 10k. However, the Owner's Manual made an exception for Malaysia and Philippines. I've been waiting for their call the whole day to confirm it. I requested a written statement coming from Mazda Philippines if the dealership will insist on their procedure for 10k change oil intervals.
I took the unit last December 19. I'm now running beyond 7,000 km. This car is not usually subjected to heavy traffic as I seldom go to Manila and Cavite.
March 5th, 2018 11:46 PM #113
March 5th, 2018 11:49 PM #114
- Dec 2007
- 727
March 6th, 2018 02:37 AM #115
March 6th, 2018 07:32 AM #116
Mazda iStop or Honda Start/Stop Battery woes?
You have the Motolite option thru dealerships w/ 1yr warranty:
OR
Finally, you have the higher spec'd, competitively priced Delkor from Johnson Controls, same maker of Varta & Optima, w/ 15mo. warranty.
For details, call or viber OVTph, +639174726847
And iStop relearning? Check this DIY:
1. Warm the engine up. Turn everything electrical off that you can - radio, A/C, lights, chargers, etc. Bring it close to electrical load.
2. Switch the ignition off.
3. Switch ignition to on but dont start engine. Long-press the i-stop OFF switch for 3 s within 5 s after switching the ignition ON.
4. Start the engine.
5. Press the i-stop OFF switch. Verify that the i-stop indicator light (green) flashes and stays flashing. If it does not flash, go back to Step 3.
6. Allow the engine to idle for 10 minutes, or until the i-stop indicator light (green) turns off. Mine didnt stop flashing so after 10 minutes or so i just went to step 7.
7. Switch the engine off. Wait a minute or two.
8. Start the engine. Go for a drive, and check that the i-stop system operates normally. Those with i-stop will know that you may need to drive a mile or two until it activates. Remember that i-stop will not operate when (a) for diesels...when engines are in DPF regen mode, and (b) in those other conditions stated in the manual. Also, if a new battery was fitted, it may take some time for the new battery to fully charge up before i-stop will start working. Go for a decent drive so it gets fully charged.
9. If i-stop operates as normal, reset it was a success.
March 6th, 2018 11:43 AM #117
Would've been better to just start a new thread instead of flooding the forum with the same post ...
March 8th, 2018 07:24 PM #118
April 5th, 2018 01:32 PM #119
Approximate Cost for Mazda 6 SKYACTIV-D
These are the details for the following items done during maintenance:
At 10,000 km
Engine Oil 1,700
Oil Filter 471
Total 2,171
At 20,000 km
Engine Air Filter 1,364
Cabin Air Filter 1,976
Subtotal 3,340
Total 5,511
At 40,000 km
Brake Fluid 585
Fuel Filter 2,999
Subtotal 3,584
Total 9,095
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
