Results 111 to 120 of 2085
- Mar 2009
- 32
June 20th, 2009 02:50 PM #111hello ulet bros..:D
nalaman ko lang na 6.5km/l average consumption ng b22 ko..pde paadvice ano mga pwdeng gawin and totoo ba na factor din dun ung air cleaner ko..madumi na daw and sira na..
thanks..:D
more power..
July 5th, 2009 06:11 PM #112
Good day peeps,
Logged-in after several years. Just found out about this informative thread and am just stoked to fined out so may B-series tsikoteers. Im having a B2500 restored this year and this thread sure is a gem. I hope the thread won't die. :-) btw, where can i get k&n air filters for the truck? and replacement "asthetic" rear lamps as well? does dyna ace carry them also?
Cheers!
July 12th, 2009 12:29 AM #113
Guys can I change the oem air filter of my b2200 pickup to a mushroom type racing filter?
July 12th, 2009 10:09 AM #114
Dear Cinematographer and bborces:
Welcome to our thread! Hope you stick around.
Dear ar_moj:
Sir, palitan mo na air cleaner mo, if its blocked and dirty, it will definitely affect your fuel economy. Read on for advice on what you can do. Good luck.
Although I haven't used K&N filters myself, everyone who has used them on their diesels (turbo and non-turbo) told me that malaki ang diperensya kapag kinabit mo sya - both the power and the fuel economy and in the reduction of smoke.
So na-intriga ako and decided to MAKE MY OWN. You see the B2500 has a branched rubber air pipe connected to a very long inlet manifold. At one end is the air filter assembly and at the branch is a resonance chamber I dismantled it and checked it out, it has NO OPENINGS except for the connection with the branched pipe.
I disconnected the resonance chamber and bought a small, second-hand air filter assembly that fits in the space available. I had to make my own fittings to connect it properly but eventually everything worked out.
After naikabit ko na ang lahat I can say that lumakas ang hila, nabawasan ang usok at tumipid ng konti. Pareho ba ang resulta sa K&N? Well I can't say as I haven't tried, BUT the whole thing cost me around Php P1,000 only so in that sense, malaking gastos ang naitipid ko.
Another thing is that the original filter is about 8" in diameter and 10" long, while the auxiliary filter (for want of a better name) is about 6" in diameter and 10" long also. They are both paper-element filters and are disposed after 5 000 km of use. I clean them every week.
Although the K&N filters are washable (and the filter screen can be replaced) I have always noted that a considerable amount of dust and dirt do get through. They have inferior filtering abilities.
That's one of the reasons I decided to stick with the paper-element filters, after three months of use, look on the inside of the K&N filter - its full of fine dust, not good for the engine, perform the same test on the paper element filters, even after six months or more... NO DUST on the INSIDE.
It MAY be that the K&N filter may flow more than my set-up (although I doubt it - the difference would be marginal) but it also definitely lets through more dirt. Since I value engine life over short-term performance that's a sacrifice I'm willing to make.
As to the mushroom-type air filter, well I'm an old man and have tried almost everything, including those when I built high-performance cars back in the 1980's (kitaam - cno mas matanda sa atin!).
They look good but don't really flow that well (especially kung nag-backfire ang carb mo at naging crispy na ang foam element nya) and don't filter too well either. So my advice is to stick with paper element filters, just find a way to modify them so you can use more than one.
Back when the air filter elements were all round or oval, we would cut a rubber gasket to glue between them and stack several one on top of the other! Hah... nasubukan nyo na yan? The whole thing would stick up out of the air cleaner assembly but in most cases would still clamp down, especially if the cover used a central bolt with a wing nut to tighten it down.
Just my 2 cents,
Best Regards,
Dusky Lim
PS - Hi guys! I make (and sell) a very effective diesel fuel additive, please PM me if you're interested. Thanks.
- Jan 2008
- 20
July 13th, 2009 12:31 PM #115sir duskylim,
can u please photos of your make shift air filter? i've always wanted to do that and seeing what u did would really shed some light..
tia
July 15th, 2009 12:49 AM #116
Dear cbgavin:
It isn't really that pretty or clean a setup (kaya nahihiya ipakita) suffice to say that it just consists of a filter attached to the small branch of the B2500's inlet hose - puro rubber hose and hose clamp lamang sir.
What you do is to cut the short plastic extension off the inlet of the resonance box so that you have something to attach to the end of the (new) hose which clamps to the new auxiliary air cleaner - that's all.
All you need is that part, an appropriate second air cleaner assembly and good quality hose clamps (I recommend US brands).
I did not fix or mount the thing, just glued foam rubber to it and let is rest against the inside of the fender... the rubber is there so it won't rattle too much.
Best Regards,
Dusky Lim
July 22nd, 2009 01:34 PM #117
Thanks for the info sir Dusky.:cool01: Sayang ngayong ko lang nabasa thread na ito. I already changed my oem filter to a simota filter last Sunday. Since nag blow by na last R2 engine ko, I changed it to an RF Turbo Intercooler, ano kaya effect ng simota filter sa performance, meron kaya o wala or even baka may bad effect. Currently under observation ko ung pickup ko, sa ngayon ok naman ang takbo b2200 ko. Pls advice sir.
July 24th, 2009 02:10 PM #118
Dear bborces:
Sorry for the late reply. I just got around to reading my e-mails and stuff now. Been really busy lately.
I remember reading online (somewhere) where a UK based car-magazine compared the leading brands of aftermarket high-performance air cleaners, including K&N and simota.
Di ko na matandaan ang pangalan ng magazine or url, but I'm sure you can still find it if you do a Google search.
From what I remember, compared to the OEM cleaner, all of them flowed more but many of them let through much more dirt.
I don't even remember the scores or the leading brand but it definitely was not K&N.
Anyway just check to see if nagiipon ng dust sa likod ng mesh filter, thats probably the most practical way you'll find out.
Hope this helps.
Best Regards,
Dusky Lim
PS - Keep on trucking!
July 25th, 2009 09:36 AM #119
hi guys! hope the mazda b-series owners get to have an eb so we can also exchange ideas and hopefully start a club.
can't post the pics here. dunno why. but it's in my album. kindly check it out and tell me what u think. it's my first pickup truck. i had it since 1998.
i have used a K&N and it really made a difference in throttle response, power, torque, and mileage. pair it with new exhaust headers and it'll have more power! it's the basic upgrade that would increase one's driving happiness.
i guess it also depends on the person's driving habit.
i also have pics * www.cardomain.com/id/azzkkr2600
cheers!
ronn
09175062616
July 27th, 2009 02:12 PM #120
Hi guys! i agree with ronn about the possibility of an eb for use b-series owners. It will be a huge help for each and everyone if we can get to know each other personally and have a change to exchange tips and ideas about our trucks. I bought my truck last year so I am really a newbie when it comes to the truck.
Ronn, count me in sa EB. Sir Dusky is also game for the EB.
Jofel - 09228429321
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
