Results 1 to 10 of 21
- Jun 2013
- 20
February 18th, 2014 12:06 PM #1Good Day!!
i have some problems about our mazda 3 brakes, kc everytime na malulubak ako or sudden brakes bigla nlng lalalim yung brake pedal nya, kaya medyo kakabahan ako kasi medyo hihina yung brakes nya, pero after ko ipump ung brake pedal babalik sya sa dati, ano kaya yung problems nya s brakes?
February 18th, 2014 02:05 PM #3
Verify mo rin kung kailan ka last time nag pa bleed and renewal ng fresh brake fluid? Napa check mo na rin ba kung may leaks?
- Jun 2013
- 20
- Jun 2013
- 20
February 18th, 2014 02:54 PM #5
February 18th, 2014 03:13 PM #6
Sir try this, may help you diagnose para di ka lokohin kapag nagpagawa ka.
Troubleshooting a Low or Sinking Brake Pedal
February 18th, 2014 03:14 PM #7
If you are sure na walang leaks sa brake master, and inside the cabin sa brake pedal.
pa-bleed mo brake system mo, might be trapped air bubbles kaya ganyan brakes mo.
at the same time, check brake pads and pacleaning ka nadin ng brake drum shoes.
If you had these done and medyo lumulusot padin yung preno,
might be palitin na yung piston ng brake master mo, pwedeng i-repair kit yan
or kung medyo na-ukit na yung cylinder, brand new brakemaster assembly na ang solution dyan.
pero either way, if ako ang may-ari ng kotse, palit nalang ako ng OEM brake master assembly.
maging top priority mo yang preno sir.Last edited by 7138; February 18th, 2014 at 03:16 PM.
- Jun 2013
- 20
February 18th, 2014 05:35 PM #8
February 18th, 2014 06:35 PM #9
- Oct 2007
- 21
February 19th, 2014 05:43 AM #10Sir just to verify lang, nag kikick-in ba yung ABS pag dumaan kayo sa lubak and lumalalim yung preno? I'm also a Mazda 3 owner po (V - 2005 model) kasi and I've ran into similar situations with my unit. Just to share my story (sorry mods kung nobela) Immediately after the ABS operates, either because of potholes or sudden braking, lumulubog yung preno. It eventually goes back to normal however, when I pump the brakes or just by continued use nung auto. My online research came up with two most probable culprits. Either the brake master failing or the ABS pump having issues. Then 3 months ago, nangyari uli yung issue but this time, hindi na bumalik sa normal yung preno. Kailangang sagad to the floor na talaga yung apak para mag-full stop yung auto. I was expecting the worst but what I initially did was to follow what most of the auto-gurus here always suggest... start with the simplest and cheapest possible solution first, which in my case was to do a total system flush/refill of the brake fluid. Lo and behold, it worked! Balik agad yung normal feel at operation ng brake nung auto. To this day, I have not experienced the same issue kahit na nadadaan pa ako sa lubak and even after mag operate ng ABS. Hope this is also the same case with your unit.
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
