Results 1 to 10 of 15
Threaded View
July 11th, 2022 12:20 AM #2
Once you take away the bolts, you can now remove the caliper brake by sliding it. Make sure to use a wire to secure it in such a way that you don't stretch the brake hose.
You can now remove the brake pads.
You also need to remove the caliper sliding pin. You can put back the bolts you removed earlier so that it will be easier to pull the caliper sliding pin if it's stuck.
Take note of the position of the pins. You cannot interchange the upper and lower caliper sliding pins.
If you want, you can also remove the rotor. You need to remove the bolts holding bracket.
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
