Results 1 to 4 of 4
March 4th, 2009 11:47 AM #1
i have to make hatid for a relative this weekend at the new naia terminal 3. what route or streets should i pass if im coming from roxas blvd?
- Sep 2006
- 227
March 4th, 2009 12:11 PM #2The quickest way(but not the shortest) might be to take macapagal ave. until the uniwide coastal, turn left in the street, cross roxas blvd(or is it coastal road stretch already?) go straight until N.Aquino Ave. turn left again....drive straight passing through the old Domestic airport and turn right in Andrews Ave....just follow this road and you will reach terminal 3.
I also attached a link to a general map of the area...
http://ph.pagenation.com/mnl/This+Sp...14.5198875.map
- May 2008
- 24
March 4th, 2009 02:11 PM #4yes po, left at park and fly. straight to the end of the road, make a right (at the rotunda) then follow the road. T3 should be at the right side of the road..
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
