Ask ko lang... How do you clean and detail the wheel wells of your vehicles? Care to share some special tips? Thanks.![]()
i put my car on jack stands, take out all the wheels, use brush for mud and more challenging dirt or use old wash mitt (which I first heard from either ILD or Dehadista). if I've got leftover (say last 5-10 sprays) from my protectants/dressings, I spray them after they're dry from the wash... it's product waste IMO but it's kinda rewarding to look at even if it's just for the first few meters anyway. :-D
tip: try to clean as much of your wheel well everytime you wash so you don't get piled up dirt once you get the time to detail them...
I'd much rather have the car sent to a wash bay that does underbody then have the wheels removed so they can clean the wheel wells. Give them a generous tip if you're picky on how they do it, so when you go back they will do a better job (hopefully)
Use a thick durable nylon brush. If it has plastic covers see if you can remove them, as sometimes the mud can accumulate inside the covers especially if you waded through flood.
Yep, it's very rewarding indeed.
coincindentally, I do my own "underwash" too (this is where my BnD PW1300 pressure washer is often used, anyway).
most of the carwash (read: not gasoline stations) in my place just use either
a. a ramp that's about a foot or two above the ground with a "bunker" in the middle or
b. a separate bay with a "bunker".
So I just do it the dirty job myself. Whenever I'm home, I've got all the time in the world anyway. Plus this gives me the opportunity to really detail my wheels too...and, more importantly, I need the exercise too...
and yes, I have to agree, it is very rewarding...
nice tip on the plastic covers too mbeige...
During washing, you can use a thick foam then scrub your wheel wells while spraying it with water. Never use steel brush![]()
It's so rewarding to see your wheel wells free from dirt and retain its blackish color.![]()
I use my hands from time to time to remove the clumps of dirt. of course I spray this with water.
I just try not to think about what I'm actually touching.![]()
I agree.Yun nga lang, sabi nga nila, "sanayan lang yan".
As regards cleaning the wheel wells, I just use soapy water and a brush. On the other hand, with regard to detailing the wheel wells, I have been following this tip I got from another forum where Armor All original protectant is mixed with water (1:1). The mixture is placed in a spray bottle where you spritz the wheel wells. In my experience, nagiging dark yung kulay ng wheel wells. And perhaps it's just me, pero I have noticed na hindi nagiging thick ang putik at buhangin sa wheel wells ever since I started following this tip.
prefereable ba na Pinturahan ang Wheel well? or even if DiY, spray painting with Undercoat paint? (nakalimutan ko ung tawag eh)
Same here.Hehehe.
Using your hands would more or less ensure that you get to remove those caked up dirt without damaging the undercoat or paint in your wheel well.
I once drove in the province where lots cows and carabaos leave their brown frisbees on the road... hehehe... hindi ko na siya kinamay. For that, I used a pressurized washer to clean my wheelwell.![]()
It's so annoying in the Phil where the street dust is fine white/brown and clings to the wheel wells like glue, unlike when I was in the US, wheel wells can be "wiped" clean after a day's trip grrr...
Tama po kayo! Every after use,have it spray with water para di tumigas yung putik and dumi sa wheelwell. Sa akin,i wipe it pa with tire black after drying and cleaning it.Sakit lang sa braso and sugat kasusungkit.
