Results 1 to 7 of 7
- Sep 2013
- 375
September 20th, 2013 03:01 PM #1mga 205/45r17 offset 45 sa mags and tires kindly help me? matagal ko na rin to inaaral pero medyo may kalituhan parin
ano po ba ang 205? at yung 45? sa mags at tires
pano ba malalaman sa spec ng mags kung pasok ito sa goma? saka pano malalaman kung magkakaroon ng rubbing issues?
sana may makatulong sakin big help po ito. salamat sa magrereply
- Sep 2013
- 375
September 21st, 2013 02:24 AM #4
205 = width of the tire
45 = aspect ratio (aka width of the tire sidewall) the lower the number the lower the profile of your tires.
Offset = The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel.
rXX = obviously the size of your rim.
Since you have +45 offset, having lesser offset like +35 or +30 makes your wheel go inwards and can give you the rubbing issue. Having more than your optimal offset, like +50, +55 will make your wheel stick out your fender's area. It's not a good look either.
For the width of the rims, you have to look into your car manual or go search the web. For example, your rims are 17" in diameter and has a width of 7" or simply 17x7, I think you can buy tires ranging from 205 up to 225 give or take a few. Going with wider tires with 7" rims will make it a "stretched" look on your tires. Take note also that going wider tires route will increase fuel consumption as you're now gripping the roads better and it needs more fuel to move those tires. Increased traction is the benefit of these.
Hope this clear things up.
So stick to your current offset and start from there.
September 21st, 2013 03:06 AM #5
Check the links below for further reading regarding tires.
http://www.tirerack.com/tires/tirete...e.jsp?techid=7
http://www.tirerack.com/tires/tirete....jsp?techid=25
http://www.tirerack.com/wheels/tech/...jsp?techid=101
- Sep 2013
- 375
- Sep 2013
- 375
Lynk & Co Lynk & Co Opens First Dealership In The Philippines | CarGuide
Lynk & Co Philippines
