Results 1 to 13 of 13
    Jan 2013
    Meron na ba nakapag try na stetch tire? Share naman kayo pros and cons interested kasi ako itry.
    para saan? for performance? for drifting?
    technically, there should be no performance benefit.
    performance should come from the tires, brakes and suspension, not the wheels. the wider the tire, the better the grip. obviously, if you widen your tires, you loose response. this is the reason why it is very important to properly match the wheels and tires.
    so stretching is done for cosmetics or probably on an economic basis (bili ka ng mas maliit na tire kaya mas mura). you stretch the tire and the sidewall is not parallel na to the wheel face. if you are on negative camber, it will allow you to use lower offset rims and wider wheels.
    If you're stretching the tires the contact patch is smaller than it could be. More contact area = more grip in corners. i don't know how this can be applied sa drifting (no idea how it works). pero kung daily drive sya, not only would it compromise your handling, it will compromise your safety as well. mas madaling madamage ang tire pag ganun.
    imho.
    I fail to see any benefits to tyre stretching. Kinda looks dumb too (sorry as i grew up with mud tyres and plus-sizing tyres... the bigger the better... hehe).
    Unless your joining a drift of drag race which stetch their tires to warm up for traction (i guess)...no use in everyday driving experience...Unless you want to burn rubber as often because you are a part of a racing team with tire sponsor...(which every car enthusiast is dreaming for )
    Quote Originally Posted by mateomarco View Post
    since when did real drifters and drag racers use stretched tires?
    no pros only cons. don't waste your money and look stupid at the same time.
    Quote Originally Posted by foresterx View Post
    opps...sorry sir...got confused...i was thinking the burnout tires! Agree with you sir...it looks weird, for me ..I guess may binabagayan din itong type of car?
    nope, walang binabagayan yon. it's just another fad for ricers like hellaflush or bikerack on the roof.
    ^^^ahaha! Bikerack without a bike you mean?! Nuff said!
    yup, bikerack without a bike. again no pros only cons.:bwahaha:
    Makes you look sporty.
    Aug 2004
    A slight stretch (emphasis slight... ) will stiffen the sidewalls, giving better response. Cheap trick for racing... using same tires, the tires will have stiffer sidewalls and will respond better on wider rims.
    What the hellaflush guys do, stretching the tire extremely, puts a lot of stress on the bead and inner lip of the tire... and could lead to premature failure.
    Quote Originally Posted by fanboi View Post
    Tire stretching PROS:
    - none
    Tire stretching CONS:
    - less tire grip
    - potential wheel damage
    - bad handling
    - tire will not last as long
    - bad ride
    Apr 2013
    For looks lang yan, sir. But stretching the tire just minimal will slightly strengthen the sidewall. Yung almost sakto yung sidewall sa lip ng rim pag tinignan mo. But going for extreme hellaflush look is just dumb. May friend kasi ako na naka Nissan Cube na naka flush look then I get to ride with him and the ride is terrible. It's like riding in the back of an empty Elf Truck.
Tire Stetching, Pros and Cons
