Car newbie here. tanong ko lang anung mga SOP kung magpapalit ka ng mags
i heard kailangan mo mag pa wheel align ... what else?
usually, di na kailangan ng alignment.
wheel balance ang mandatory
wheel balancing...check the proper offset and proper specs of the mags for the car!
Good day sirs. Balak ko din mag palit ng size ng mags ng crv '02. Any suggestion sirs? TIA
check out 1010tires.com, they've got a tire calculator that recommends which size tire you should buy when changing rims.
wheel balance, this is a must kung saan mo papakabit yung tires sa mags (para libre)
alignment, also a must to make sure proper toe and camber (though more associate to lowering a car rather than just installing after market rims) or else di pantay ang kain ng gulong mo
and yes, proper offset and specs of both the mags and tires for your car
