Results 1 to 7 of 7
    Aug 2012
    Car newbie here. tanong ko lang anung mga SOP kung magpapalit ka ng mags
    i heard kailangan mo mag pa wheel align ... what else?
    Jul 2006
    usually, di na kailangan ng alignment.
    wheel balance ang mandatory
    Jul 2012
    wheel balancing...check the proper offset and proper specs of the mags for the car!
    Sep 2012
    Good day sirs. Balak ko din mag palit ng size ng mags ng crv '02. Any suggestion sirs? TIA
    Aug 2012
    check out 1010tires.com, they've got a tire calculator that recommends which size tire you should buy when changing rims.
    wheel balance, this is a must kung saan mo papakabit yung tires sa mags (para libre )
    alignment, also a must to make sure proper toe and camber (though more associate to lowering a car rather than just installing after market rims) or else di pantay ang kain ng gulong mo
    and yes, proper offset and specs of both the mags and tires for your car
    Dec 2007
    Quote Originally Posted by pcuerpo View Post
    Agreed.
    But before all that: make sure the wheels you're buying have the correct PCD and number of lug holes for your car :D
SOP when changing rims
