Results 1 to 9 of 9
- Oct 2011
- 9
July 16th, 2014 11:14 PM #1Hi guys, I currently using 18 inch Rota P1 wheels with 225 40 tire. Recently, I hit some rough road and slightly bent all four mags. Bents are very slight and no air is escaping. They are also hardly noticeable and needs up close inspection to see. The bents are on the outer lip while the inner lip is intact and still circular.
I was wondering if I should have this repaired or maintain it as is? Will it be safe to drive? and wont I have problems in the long run? suspension? uneven tire wear?
I will be posting the pictures tomorrow.
By the way, I'm also a bit concerned as the mags get easily bent. What should I do? Should I change my tire to 225 45 series? What other options should I do to avoid this in the future.
July 16th, 2014 11:27 PM #2
Paikutin sa balancer para malaman kung pwede pa.
Kung malala, hindi na mababalance yung wheel.
- Oct 2011
- 9
- Oct 2014
- 1
October 22nd, 2014 11:35 PM #4good day i also have slighty bent mag 18" can you help me or do you have some idea where can i send this for replace locally.
October 22nd, 2014 11:44 PM #5
had a similar problem before and the balancer couldnt fix the bengkong. What i did was to have it fixed by a specialist / machine shop. Dont know how safe it was... but the rims lasted for more than 5 years without problems before i sold it. Hope this helps.
- Jun 2010
- 3
October 27th, 2014 12:02 AM #6Saan po pwede magparepair ng mags na bent or oblong na? QC/Manila area sana. Thanks.
October 27th, 2014 12:31 AM #8
October 27th, 2014 01:54 PM #9
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
