Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
    #41
    depende yan sa preference mo.
    if you wanna sacrifice comfort over looks then 22. extra careful ka nga lang palagi when driving. pag may lubak extra careful baka mabengkong mags. dahan dahan ka na rin patakbo kahit konting lubak lng dahil sigurado aalog alog ka nyan sa loob.
    visit mo fb or website ng bcc chrome wheels city. dami sila pics ng montero naka 20s and 22s.
    Feb 2009
    #42
    Quote Originally Posted by [archie] View Post
    ^^ Kung masyadong pasok pwede spacer.
    Be careful, check the change in scrub radius that affects braking, steering and wheel bearing service life
    Feb 2011
    #43
    Quote Originally Posted by Montz View Post
    Mga Sir.. question lang, safe kaya 22' mags for montero? hindi ba takaw bengkong kung goma is 285 40 R22? advise please. torn ako sa 20 at 22 rim size for montero sana mga sir. any suggestions? thanks!
    Maganda yang 22" sir. With those specs, the sidewall would still be 4.49", so hindi naman masyadong manipis. If in doubt, I think kaya pa ng tire well ng Monty natin ang 45 or even 50 series. Yun lang may difference na sa odometer reading natin.
    #44
    noted sir, another thing is ok lang ba na yung goma sa harap is 285 40 r22? then sa likod is 305 40 r22? may magiging problem ba pag ganito set of tires sir? thanks!
    #45
    Kapag nagpalit ng mags mas malaki yung center bore diba? Kailangan ba magpalagay pa ng center ring?
    Feb 2009
    #46
    If you have four channel antilock brakes, yes, big problem
    If you have all wheel drive,yes bigger problem
    #47
    im not familiar with four channel antilock brakes sir, meron ba mga montero neto? i have a montero 4x2 gls model.
    #48
    Hi everyone, just wanted to ask for advice. Where's the best place to purchase a Michelin tire. I was thinking of getting the PS3 sana. TIA.
    Jun 2014
    #49
    try OTANI malapit sa suki market
    Mar 2016
    #50
    Mga sir/mam, Newbie lang po ako. Tanong ko lang po kung anong maganda mags para sa Hyundai Accent 2016 Sedan (Sleek Silver) at kung anong size ng tires ang bagay? 14" or 15"?
    #51
    Quote Originally Posted by Tricioman_ View Post
    sleek silver would look good in a black spoked-type rims with chrome lip.
    15 would be an excellent choice, but you can go 16 too. as long as yung offset nung new mags mo is compatible.
    Jun 2012
    #52
    Pag 20s mga sir, ilan ang allowable na max air pressure pag fully loaded (7 pax) pati roof rack? sabi kasi 30 lang, kaso parang kulang lalo na pa from cavite to bicol. TIA
    #53
    Pareho tayo bro, but mine is a hatchback, color red. Kung metal rims pa ang nasa auto mo, those are size 14x5j with offset of 43mm. Go with 15x6.5j na lang. Wheel dealers don't sell 16s, straight to 17s. Problem with 17s is that the ride becomes harsh & may shorten suspension life. It might also become an issue, come warranty claims. Take note of the rimwidth also. 7j & above may cause rubbing on the bodywork or suspension parts, depending on the offset of the wheels. BTW, careful din because wheeler dealers will sell you anything. Bahala ka na kung magka problema. Check this out also:arbibles.com/tyre_bible_pg4.html
    #54
    Pareho tayo bro, but mine is a hatchback, color red. Kung metal rims pa ang nasa auto mo, those are size 14x5j with offset of 43mm. Go with 15x6.5j na lang. Wheel dealers don't sell 16s, straight to 17s. Problem with 17s is that the ride becomes harsh & may shorten suspension life. It might also become an issue, come warranty claims. Take note of the rimwidth also. 7j & above may cause rubbing on the bodywork or suspension parts, depending on the offset of the wheels. BTW, careful din because wheeler dealers will sell you anything. Bahala ka na kung magka problema. Check this out also: carbibles.com/tyre_bible_pg4.html
    Aug 2013
    #55
    Quote Originally Posted by mar04 View Post
    ano wheel at tire specs? pati anong sasakyan naka kabit?
    share ko sakin bro.
    Innova 3rd gen
    Wheels/rims: 20x8.5
    Tire: 245/40R20
    Tire pressure: 38 psi front and rear kapag madami kaming karga, max tire pressure namin dati 40 psi.
    Jun 2012
    #56
    Quote Originally Posted by innova2013 View Post
    share ko sakin bro.
    Innova 3rd gen
    Wheels/rims: 20x8.5
    Tire: 245/40R20
    265/50/r20
    montero sir. hehe.
    Apr 2010
    #57
    are there wheel/rim shops that offer 0% installment?
    Jul 2015
    #58
    Quote Originally Posted by myas110 View Post
    Check out autoplus and autoline
    Apr 2010
    #59
    thanks bro ;)
    May 2016
    #60
    thanks sa mga info.
Replacing Wheels
