Results 1 to 10 of 34
December 4th, 2013 09:23 PM #1
This afternoon, a piece of scrap metal punctured my tire:
I had it checked by a vulcanizing shop and only a third of the piece of metal went through, so the damage to the rubber was minimal. After applying sealant via heat press, the tire was back to normal again at 38 PSI.
My question is, can I still use the tire as I did before the puncture? Since it wasn't the sidewall that was damaged, and since the metal didn't pierece through too deeply, the guy who repaired it says it shouldn't be a hazard.
I'd like to know what you guys think.
If it helps, I travel about 100 km a day, mostly provincial highway. About once a month, I travel via land from Bicol to Manila and vice versa. This sometimes includes some top speed runs (which is only about 175 kph with a Ranger).
I was wondering if the tire would still be okay at that speed.
Thanks
Sent from my iPad using Tsikot Car Forums
- Jul 2011
- 1,711
December 4th, 2013 10:18 PM #2Normally the vulcanized area should be stronger than the original rubber if done properly, why not use your spare tyre ang ung damaged tyre ang gawin mong spare
December 4th, 2013 10:57 PM #3
Given the damage is to the thread portion of the tire, it should be safe to use normally even with high speed runs. It will hold just as good as your other undamaged tires.
Sent from my Nokia 5110 using Tsikot app.
December 4th, 2013 11:06 PM #4
If you must use it because your spare is worse, then use it for the rear. A high speed front tyre blow up can be deadly, a rear wheel blow up just damages your mags.
December 4th, 2013 11:33 PM #5
Actually, my spare is still fresh, unused even. It's just that I wait 10,000 KM before rotating. Now that I think about it though, this might be too large of an interval since my 4 tires are now more visibly worn than the unused spare.
Thanks for the confirmation guys on the useability of my vulcanized tire.Last edited by jut703; December 4th, 2013 at 11:35 PM.
December 4th, 2013 11:34 PM #6
Yup, its still good since the damage to the rubber was minimal granting the repair was done well.. drive safe!
Sent from my LG-D802 using Tsikot Forums Mobile App mobile appBeep Beep! School Bus! Beep Beep! School Bus!
December 4th, 2013 11:37 PM #7
December 4th, 2013 11:39 PM #8
December 5th, 2013 12:03 AM #9
i guess, one can still use the punctured tire normally as long as the punctured tire wasn't run flat. had the mistake of not noticing that one of my tires was run flat. ayun, reserba na sya.
- Jun 2007
- 1,161
December 5th, 2013 12:36 AM #10ako nga noon sa side pa yung butas ng tire (sinaksak ng mga addict).
pina vulcanize ko rin. tapos nilagay ka sa rear.
nagamit ko pa pauwi-balik ng bicol. overloaded pa kami non.
hangang sa nabenta ko na yung sasakyan, ok pa rin yung mga gulong.
That was the high mileage cars thread:...
The Toyota Fortuner has landed (fortuner pics at...
