Results 1 to 20 of 34
    If you must use it because your spare is worse, then use it for the rear. A high speed front tyre blow up can be deadly, a rear wheel blow up just damages your mags.
    Actually, my spare is still fresh, unused even. It's just that I wait 10,000 KM before rotating. Now that I think about it though, this might be too large of an interval since my 4 tires are now more visibly worn than the unused spare.
    Thanks for the confirmation guys on the useability of my vulcanized tire.
    Oct 2011
    your unused spare trye might be fresh but still it ages with time.
    4 months palang naman hindi nagagamit yung tires. Within the month I'll hit 10,000 and have it rotated.
    May 2012
    i guess, one can still use the punctured tire normally as long as the punctured tire wasn't run flat. had the mistake of not noticing that one of my tires was run flat. ayun, reserba na sya.
    Jun 2007
    ako nga noon sa side pa yung butas ng tire (sinaksak ng mga addict).
    pina vulcanize ko rin. tapos nilagay ka sa rear.
    nagamit ko pa pauwi-balik ng bicol. overloaded pa kami non.
    hangang sa nabenta ko na yung sasakyan, ok pa rin yung mga gulong.
    use the spare. spare the punctured-but-repaired tire. file it under "tire rotation", which is what we should be doing, anyway.
Punctured Tires - Can I still use them normally?
